AMS F1 vs Magnus V5
Old Feb 16, 2010 | 08:51 AM
  #286
Sean@Iveytune's Avatar
Back at the end of last yr, owner of DI came to us and submitted his latest manifold with dual injector rails etc.
We have been sitting on it for a while but we got some time to test it today.
We used the same method of testing as before, no adjustment to the maps unless there was something dangerous going on, and we tested off WG spring (17-19 psi) pressure then 29-30psi, all on pump fuel.
The only item changed was the intake manifold for the testing.
The mod list should be back in this post somewhere, nothing else was changed other than the intake manifold, and related movement of items associated with it, dipstick etc.
There was a boostleak test performed prior to the test on the dyno, to ensure no leaks were present.
I am not going to comment too much I want to provide the data as is, as collected.
Please let me know if there are any errors as the car is still in it's current state and can be put back on the dyno for further testing.
Attached Thumbnails AMS F1 vs Magnus V5-dpp_3022.jpg   AMS F1 vs Magnus V5-dpp_3011.jpg   AMS F1 vs Magnus V5-dpp_3009.jpg
Old Feb 16, 2010 | 09:16 AM
  #287
Now for the results.
There will be 2 sets of runs, the titles should explain what is going on.
Attached Thumbnails AMS F1 vs Magnus V5-di-low-boost.jpg   AMS F1 vs Magnus V5-di-high-boost.jpg
Old Feb 16, 2010 | 09:21 AM
  #288
JesseB's Avatar
I take it the DI was the final 2 runs on each graph?
Old Feb 16, 2010 | 09:22 AM
  #289
They are all DI.
One set are all the low boost runs, the other set the high boost runs for the DI.
Sean
Old Feb 16, 2010 | 09:31 AM
  #290
DDATuned's Avatar
Ams F1 - Peak 646hp / 518 tq
Driven - Peak 623hp / 519 tq
Thanks for the testing Sean.
Old Feb 16, 2010 | 09:41 AM
  #291
Drifto's Avatar
Nevermind....
Old Feb 16, 2010 | 10:04 AM
  #292
Aby@MIL.SPEC's Avatar
where is the ams-f1 dyno plot?
sorry for not following this thread from start till now...
i dont feel like going though 20 pages to not find see 1 posted in this thread.
Old Feb 16, 2010 | 10:08 AM
  #293
Driven Innovations's Avatar
https://www.evolutionm.net/forums/7808401-post119.html
Old Feb 16, 2010 | 10:14 AM
  #294
mmolch2's Avatar
ams ftw as usual
Old Feb 16, 2010 | 11:04 AM
  #295
Comparison plots as requested.
Attached Thumbnails AMS F1 vs Magnus V5-di-ams-high-boost.jpg   AMS F1 vs Magnus V5-di-ams-low-boost.jpg
Old Feb 16, 2010 | 11:09 AM
  #296
R/TErnie's Avatar
If you haven't posted it already...
Do you have the Magnus v5 vs. the AMS F1?
Thank you Mr. Ivey for sharing your testing and results. GREATLY appreciated.
  #297
scorke's Avatar
So the ams makes more power and doesn't give up any down low.
Engineering works!!!
Scorke
Old Feb 16, 2010 | 11:27 AM
  #298
Colt4g63's Avatar
Very good to see this tested! Thanks to all partys involved!
Old Feb 16, 2010 | 11:31 AM
  #299
Mellon Racing's Avatar
Sean would you mind doing an overlay with the best run from both so it's easier to compare?
Old Feb 16, 2010 | 11:33 AM
  #300
Colt4g63's Avatar
Scorke
X2
