AMS F1 vs Magnus V5
Old Dec 17, 2009 | 10:27 AM
  #121
scorke's Avatar
Man look at how clean that car is under the hood!!!
Engineering=Results.
Scorke
Old Dec 17, 2009 | 10:34 AM
  #122
binky's Avatar
Thanks for doing this! Your hard work is much appreciated
-Bink
Old Dec 17, 2009 | 10:36 AM
  #123
AWD Motorsports's Avatar
Originally Posted by Sean@Iveytune
Just finished back to back testing of the AMS f1I, vs the Wilson V2 intake mani.
Car is still strapped to the dyno for backup tests.
BR 2.3
Kelford 280 deg cams
Headgames head
HKS DLI
BR IC and Pipes, race core
BR 3" exhaust
Full race 4088 Turbo kit twin scroll
AEM EMS
1000cc Bosch Injectors (ID)
Wire tuck by my Tech Will! :-)
Before with the previous setup we were stuck around 604-602 wheel a few days go, after putting the AMS intake on WITHOUT DOING ANY TUNING AT ALL, at same 30psi boost had to be upped on the AEM boost controller, it belted out 63x, cooled it a bit and ran again 64x.
This is all done on 93 octane pump gas, and before anyone starts their nonsense this isn't an absolute test, your results could vary, but I believe that it shows a certain tendency.
We also tested between 2 different sets of cams back to back on this car, but we are not sure we are going to release the results.
For those in the area the car is still on the dyno.
Same gas, same boostleak test before both tests, temps similar. This is not a lab but we are trying to keep everything as similar as possible.
Sean
Looks like the AMS F1 took a dump on the Wilson.. Doesnt suprise me at all.. With the R&D AMS does vs. Wilson as far as Evos go its no suprise!!! Nice to see it didnt lose any bottom end either.. As far as i see there is 0 advantage to the Wilson V2 vs. the AMS..
Mike
Old Dec 17, 2009 | 10:59 AM
  #124
David Buschur's Avatar
I'm with you Mike. I talked to Ivey and am convinced the testing was done in a manner close enough to show those major gains to be factual. That's a LOT of power on pump gas, nice job Sean.
Old Dec 17, 2009 | 11:29 AM
  #125
Mellon Racing's Avatar
very nice gain
Old Dec 17, 2009 | 11:57 AM
  #126
Evokid03's Avatar
DAve, now compare your manifold with the ams manifold so i can make my purchase decision
Old Dec 17, 2009 | 12:30 PM
  #127
Dragracer187's Avatar
I think there are some people here willing to send their mani to Sean for testing. I really hope this happens, if Sean is willing to do further testing ofcourse. I think lots of people want to see the comparison with Buschur, Magnus, DI and maybe others.
Old Dec 17, 2009 | 12:52 PM
  #128
Sean@Iveytune's Avatar
Ok got back on the dyno. Ran the car a few more times off the wg just like I did with the V2, seems the difference isn't as large at the lower boost, but there is a difference.
Perhaps on this combo the F1I does better at increased levels of airflow? I will leave that for others to debate.
It is what it is. 2 runs on the F1I and 2 runs on the Wilson all off the WG spring. 17-18psi logged, as before.
Runs 58 and 59 on the v2 a few days ago, 71 and 72, minutes ago on the F1I.
Sean
Old Dec 17, 2009 | 01:38 PM
  #129
E85evo8's Avatar
those results have me very excited!! I have a locally ported stock IM which probably isn't as good as the Wilson(still is a very nice piece) so with the amount of boost I'm running and the hp I will be making, the Buschur SMIM should net me 30+whp gains if not much much more...this is a guestimate, of course!
Old Dec 17, 2009 | 01:42 PM
  #130
Geoff Raicer's Avatar
Just finished back to back testing of the AMS f1I, vs the Wilson V2 intake mani. Car is still strapped to the dyno for backup tests.
AMS F1I Intake manifold stock Tbody, replaced Wilson V2 stock Tbody.
AMS fuel rail
BR 2.3
Headgames head
HKS DLI
BR 3" exhaust
AEM EMS
it belted out 63x, cooled it a bit and ran again 64x. This is all done on 93 octane pump gas
glad to hear things are coming along well Sean, 640 on 93 is fantastic. Power gains from the AMS manifold should pick up more and more as boost and airflow are increased. The object is for it to not lose any power at lower airflow levels - the last test you did proved the AMS is definitely not losing.
edit: i hope we can finally pop on this twinscroll borgwarner turbo ive got sitting in NJ
Old Dec 17, 2009 | 02:08 PM
  #131
rgeier11's Avatar
These results need their own thread. Nice work Sean.
Old Dec 17, 2009 | 02:17 PM
  #132
project_skyline's Avatar
Very nice results. I didn't think the AMS one would fall short. What are your plans as far as testing this against others?
Old Dec 17, 2009 | 03:37 PM
  #133
Erik@MIL.SPEC's Avatar
Mike
For those of us living in California, I believe the Wilson offers the best solution if you need to look stock.
Old Dec 17, 2009 | 03:43 PM
  #134
I did forget that yes if you need to look stock the v2 could work but again in MY OPINION is still not the best solution.. I made 711hp on a Buschur ported and 712hp on Wilson with same day testing..
Mike
Old Dec 17, 2009 | 04:23 PM
  #135
Dropping boost levels and seeing the power come together makes sense to me and goes along with what I saw when I did all my testing. (Did not test the F1) I'd also put money on the F1 making more gains over the stock style intake on a stroker than it will on a 2 liter, this is based off looking at the plenum size. Larger plenums work much better on the 2.3's than on the 2 liters.
