Cessna's quest for 9's on a stock motor
Old Dec 30, 2009 | 06:16 AM
  #76
EmeryatSTM's Avatar
Originally Posted by RyuEvoIX
Nice looking build. The only thing I would have done different would be to use a recirculated BOV instead. Good luck.
Not sure why? It has speed density and with no lift shifting, it will never open all the way down the track.
-Em
Old Dec 30, 2009 | 06:53 AM
  #77
PAdutch's Avatar
Wow awesome build, its amazing what the stock block is capable of. Good work STM, car looks great.
Old Dec 30, 2009 | 09:11 AM
  #78
RyuEvoIX's Avatar
-Em
I am aware this setup includes speed density and nlts, so does my setup. Regardless of how little the BOV opens in between shifts the fact still remains it does open. I have seen the results of independent testing in wich it has been proven that recirculating decreases the rebound time it takes to ramp back up to full power.
Your going through the trouble to increase flow with larger fittings on the valve cover, why waste air that's already in the charge system? Just seems like an over sight to me in a project where you are obviously trying to squeeze out every ounce of potential.
Old Dec 30, 2009 | 09:28 AM
  #79
CMB's Avatar
CMB
I agree with the first part but what the hell are you talking about in the second part? Whats does the valve cover fittings have to do with anything?
Old Dec 30, 2009 | 09:46 AM
  #80
MOREPSiTEHBETT4's Avatar
vacuum
  #81
murderedevo256's Avatar
So the catch can only has one line going to it and the other side will stay with the filter on it? Its a really nice setup and I definitly will pick that up when I finish figuring out all of what I need
Old Dec 30, 2009 | 09:49 AM
  #82
RyuEvoIX's Avatar
I referenced the fitting to show that stm is willing to do the little things to achieve peak efficiency out of this setup, so why overlook something so obvious as recirculating the BOV?
Old Dec 30, 2009 | 09:50 AM
  #83
Driven Innovations's Avatar
Looks great Em! Good luck with your goal guys!
Old Dec 30, 2009 | 10:35 AM
  #84
EmeryatSTM's Avatar
Why would the BOV open if you never let off of the gas?
-Em
Old Dec 30, 2009 | 10:49 AM
  #85
RyuEvoIX's Avatar
-Em
The moment you disengage the clutch to perform a shift the vehicles load drops thus causing the BOV to crack open. Log it yourself if your interested in seeing it first hand. You will not maintain full calculated load in between gears during nlts.
Old Dec 30, 2009 | 11:43 AM
  #86
EmeryatSTM's Avatar
I understand that, but the boost will stay 1:1 as long as the Throttle body stays open. Boost is only a part of the load equation.
-Em
Old Dec 30, 2009 | 12:39 PM
  #87
Cyloc's Avatar
I agree with Ryu on this. Even with NLTS the valve will open, every so little. I have logged this on both my AEM and my stock ecu. I have seen loses in boost of anywhere from 5 to 12 psi drop between shifts. At a .25 of a sec shift it is about 5 psi and 1 sec is about 10 to 12 psi.
I have also been in car with some well known drivers and logged while they drove. The smallest loss in boost I ever saw was 3 psi between shifts on NLTS. The shift time was .12 of a second.
I believe the point he is making is that the recirculated BOV can help with this drop off. It has been proven that with a recirculated BOV the loss of boost and rebound is minimal. The test that were done showed that if a person shifted in .25 of a second there was about a 5 psi difference in boost loss. And a person that shifted SLOW at about 1 second saw a 1 psi difference. It showed that having a recirculated BOV was in fact good to have. These were done on a stock turbo. It helped keep the wheel of the turbo spinning and helped cut the rebound times almost in half.
Old Dec 30, 2009 | 01:37 PM
  #88
evovin's Avatar
True!
Old Dec 30, 2009 | 02:46 PM
  #89
Draven83's Avatar
The exhuast is a HKS hi-power cat-back and buschur downpipe and test pipe. Also running a JMF o2 dump. I will however be getting rid of the HKS in turn for a buschur cat-back.
Old Dec 30, 2009 | 03:06 PM
  #90
EmeryatSTM's Avatar
I understand and am Aware that the Boost falls off. I just cant see how the valve will open if it remains 1:1 like it should if the Throttle body never closes. I will try it on the dyno and video it with the GOpro. Easy enough.
-Em
