would this work?
Old Jan 7, 2010 | 11:47 AM
Davethewave's Avatar
would this work?
evo motor/drivetrain
has anyone bought one of these and built it? i mean would it work (after its been built) on an evo 8? ive been talking about doing a build for a while now, and i was just wondering how much of a difference there is in the heads? some of you might say "why not just build your current motor, or buy a USDM one off the forums?" well that might be an option, but for now this seems like a better deal. i mean come on, $3000 for a motor with all the accesories and it comes with a tranny and a t-case.
my attraction to this has nothing to do with the fact that its "JDM". i just want a great deal on a motor tranny and t-case that i can leave in my garage and build up slowly over a course of a few months as money comes in and when its finished i can do a motor swap.
i would have english build the motor
tranny and t-case would go to shep or TRE of course.
and maybe someone can chime in and tell me whether or not the evo4 exhaust manifold can be ported, i know it looks significantly thinner than the evo8 manifold.
Old Jan 7, 2010 | 11:51 AM
gsrboi80's Avatar
The motor will work for sure. TC is likely ACD equipped
Old Jan 7, 2010 | 11:54 AM
well, even if its acd equiped, do you think a 2005 evo8 ecu and harness will work? i mean the 2005 is the only year with an ACD and non MIVEC head. which would be just like the EVO4 stuff shown here
edit: i just noticed that it comes with an ECU. but my question is, was this an OBD-1 or OBD-2 motor?
Old Jan 7, 2010 | 11:57 AM
JakeTheVIII's Avatar
The price doesn't seem too bad for what it is. But then again, you just spent another $3,000 on all stock parts. You can find stock longblocks on here for $1,500-$1,800 or less, t-cases for 600-800, and trannys for 600-800.
Sure it would probably work. Would it do you much good? Doubt it. They're basically just cheap cores. Plus, the way it's sitting looks like it's putting a lot of awkward pressure on the downpipe and turbo. All the heat shields look thrashed.
Old Jan 7, 2010 | 12:04 PM
dude, im so not worried about the downpipe or the turbo, that crap would just end up right back on ebay or the forums.
im planning on doing a BBK full and MAP Rev2 manifold, and MAP O2 eliminator downpipe.
lol, look at the back of the t-case, they either couldnt get the driveshaft out, or didnt care, they left part of the driveshaft in the t-case.
Old Jan 7, 2010 | 12:17 PM
chaotichoax's Avatar
not sure if you noticed but that engine has an anti lag setup as do all jdm evos
you'd have to google whatever year the evo 4 was produced and see if they were obd-i or obd-ii standard at that point
Old Jan 7, 2010 | 12:29 PM
alright so as far as i can tell this is an OBD-II motor. as i have never examined the anti-lag system on an evo, i have no idea how i would disconnect it. i know anti-lag can be really damaging to your turbo. is it just a periperal system? like would it just come off as i stripped the motor?
Old Jan 7, 2010 | 12:37 PM
gsrboi80's Avatar
Yea the hardware for the antilag can be removed. Plus im sure you could make it OBD-II compliant. Just be a matter of the proper sensors which most are probably the same anyway, ECU, and engine harness from an VIII
Old Jan 7, 2010 | 12:42 PM
im just wondering what engine harness an ecu to use. the block will remain a 2.0, and i dont think i would want to spring for an AEM EMS. i would just have the ECU reflashed and dyno tuned.
i think im going to go with the TTP pistons, im not sure about rods, ive thought about groden but they seem a little, well overkill. i just want a set of strong rods, thats something i dont want to compromise on.
Old Jan 7, 2010 | 01:11 PM
TTP Engineering's Avatar
Aluminum rods are not overkill. The main benefit is lighter rotating mass which equates into less stress on the crank and bearings and safer high revving.
Old Jan 7, 2010 | 02:51 PM
andrewzaragoza's Avatar
looks like it has the ecu and harness so it should work. looks like its an evo 8 engine. 4G63 TH6304 and may be the 04 on the engine code means it was manufactured in 2004.
Old Jan 7, 2010 | 03:29 PM
well, thats not really obvious until closer inspection. look at the valve cover, its clearly an older engine
Old Jan 7, 2010 | 03:52 PM
It appears to be a lower compression piston older unit.
Shamrock
Feb 4, 2013 09:16 AM
Most Hated
Dec 4, 2011 08:35 AM
LI Pinky
31
Sep 1, 2011 10:11 AM
dambikeracer
26
Jun 9, 2010 07:19 PM
Disruptorzero
Dec 8, 2008 05:54 PM
