Acree's MAP 2.4L FP Black Build
Old Oct 8, 2010 | 09:26 AM
  #286
Kracka's Avatar
Head gaskets (and most studs) are one time use only.
Old Oct 8, 2010 | 09:35 AM
  #287
RockmanX's Avatar
man how do you have low compression on a brand new map 2.4 motor guezz.
Old Oct 8, 2010 | 09:39 AM
  #288
ChrisCarey's Avatar
At 20 miles do you honestly feel that this motor is completely broken in? Additionally there could be something else array, please don't jump to conclusions here. Andrew, you have a PM sir.
Old Oct 8, 2010 | 10:02 AM
  #289
920rs's Avatar
man alot of problems here..... freeze plug coming out?!!! map short block!!!
Old Oct 8, 2010 | 10:07 AM
  #290
MJ23FE's Avatar
It's def a good thing to learn. But at this point, someone who knows what they are doing should be doing this work. If it was parts that were failing i wouldn't mind, but it's all you. Yeah, blah blah blah, I don't have to read this, but it's def getting annoying. Just pay someone already and save your time and money!!!
Good luck, duder!
-Jalal
Old Oct 25, 2010 | 10:48 AM
  #291
Acree's Avatar
I've been neglecting the car for the past couple of weeks. I got the head back off last Tuesday. The PE head gasket had places on cylinder one and three where the fire ring actually came into the cylinder. There was an inch or so from each missing. This means that they broke off and when out through the turbo. So there's a concern.
KevinD from EvoDynamics came over and check for flatness of the block and head. There were a few rough spots on the head we had to lightly file down. He also checked the bore and everything came out perfect in all 4 cylinders, so I didn't over heat anything when I lost coolant.
I will be reinstalling the freeze plug later this week. Unfortunately I broke a bolt off in the turbo hot side taking the exhaust manifold off. It just seized up half way out. I will attempt to remove it with some heat and elbow grease. If that doesn't work, I'll have to take the hot side to the machine shop and get them to take care of it.
Everything going well, I'll try to start it this weekend.
-Acree
Old Oct 25, 2010 | 09:37 PM
  #292
rmondoh's Avatar
Man, how weird. I was just thinking about whatever happened with the car today and then you post an update! Good luck with it this week. Looking forward to some good news.
Old Oct 25, 2010 | 09:57 PM
  #293
Acree's Avatar
Heat/elbow grease/drill did not work. I'll be taking the hot side to the machine shop. ><
-Acree
Old Oct 25, 2010 | 10:19 PM
  #294
rmondoh's Avatar
-Acree
I said I wanted to hear "Good News"! This is unacceptable. Try again!
Old Nov 4, 2010 | 08:49 PM
  #295
X91EVO's Avatar
Registered User
yea a couple of hardships.. but imagine the money you saved doing this yourself! haha
Old Nov 5, 2010 | 09:04 AM
  #296
RockmanX's Avatar
imagine the problems that could have been created as well . always two sides
Old Nov 5, 2010 | 10:22 AM
  #297
binky's Avatar
Ahhh, but, that's how you learn
Make some mistakes, fix them and don't do it wrong again the next time
-Bink
Old Nov 5, 2010 | 11:30 AM
  #298
RockmanX's Avatar
-Bink
Yea only if you dont cause catastrophic failure with the first of many mistakes
Old Nov 5, 2010 | 11:38 AM
  #299
binky's Avatar
It's only money, right?
-Bink
Old Nov 5, 2010 | 12:44 PM
  #300
RockmanX's Avatar
-Bink
WELL when you have to redo things and put out MORE MONEY lets see how well you take to it. I have been there and there is not positive about it just sucks alway around and more time on the table and more time with a emptier wallet
