FP Green Oil Selection
Old Nov 8, 2010 | 05:27 AM
  #121
apagan01's Avatar
Originally Posted by miragevo
Amsoil 0W-30 has 1163 zinc & 963 Phos
Mobil-1 0W-40 has 1100 zinc & 1000 Phos
id like to know where you get your numbers from, since they are fully innacurate.
Old Nov 8, 2010 | 05:40 AM
  #122
apagan01's Avatar
miragevo[/QUOTE]How about showing us some current graphs and apples to apples comparisons to Mobil-1's current High mileage 10W-30 oil or their 0W-40 which is an "only" option for people buying Mobil-1.....Amsoil doesn't sell 0W-40...... Most of the Mobil-1 0W-40 specs are better than Amsoils 10W-30 specs. BTW, I did look closely at these graphs and they are almost 8 years old!!!!!! Quit beating around the bush and gather the current info, put it into a line by line and compare. Then you'll have me looking.[/QUOTE]
let me tell you something while you are over there just trying to nit pick i am here providing this community with some usefull data, data they can look at and make some sort of decision instead of me just blabbing off on a pargraph,,,, WHERE IS YOUR DATA ?? OH YOU GOT IT FROM MOBIL' S WEBSITE SO IT MUST BE TRUE
And by the way if i brought up the most current data for Mobil 1 they would be in worst shape they were in 03 in those graphs, why simply because of their additive package and how it has been diminished to certify to API and comply with all the new GM, SM and SL specs, that locked them into an oil that gives the consumer less protention and this not only goes for Mobil it goes for all other oil companies that want to sell their products on the shelfs of stores with an API stamp, this would only apply to high performance , for my 2010 Toyota Camry V6 is a different story maybe the Mobil would be enough.
I am not here to try and pursuade you, i am here to educate and let people make their own choice, those charts are a benefit for you and me, the only difference on those charts is that some of those oils would be in a worst place than they were in 03 why simply because of all the new API requirements that were implemented in 08 that has required them to reduce ZDDP for emissions.
And belive it or not Mobil loves brown nosing API.
Old Nov 8, 2010 | 08:01 AM
  #123
EvolutinIX's Avatar
Does amsoil 0w30 comply with the api standards? From another thread is 900 ppm of zddp correct? Also at what temp does the 0w30 shear?
Old Nov 8, 2010 | 11:40 AM
  #124
apagan01's Avatar
It's advertised to comply and exceed API standards, yes 900 PPM range is correct for SSO.
Old Nov 8, 2010 | 04:37 PM
  #125
EvolutinIX's Avatar
What temp does the 0w 30 shear?
babaz7
34
Oct 13, 2017 04:57 PM
Michael @ FP
Oct 6, 2015 06:57 PM
Boostedx11
May 23, 2011 09:37 PM
tephra
16
May 25, 2010 06:34 AM
maperformance
Oct 14, 2008 04:14 PM
