for anyone that has crankcase pressure issues
Old Jan 30, 2014 | 10:47 AM
  #856
WannaRace's Avatar
Would a -10an press in fitting on the pcv side and a -6an on the intake side be the same?
Old Jan 30, 2014 | 11:29 AM
  #857
EVOizmm's Avatar
Originally Posted by tscompusa
EVOizmm what you did was give yourself a problem drilling the other side of the valve cover like that. Yes it will relieve more pressure, but its going to push oil and fill the catch can now when normally that side would never see a drop of fluid.
yes, its FAR less baffled than the front side port. But its easy to put a plug on that rear port.
Old Jan 31, 2014 | 04:42 PM
  #858
mrfred's Avatar
Here is a breather option that maintains the factory PCV flow, provides good crankcase ventilation, and does not require drilling the valve cover. The downside is that the PCV port is known to suck oil under hard acceleration, so the catch can could fill up quickly under those conditions, especially without a Kiggly HLA.
Attached Thumbnails for anyone that has crankcase pressure issues-mod-pcv-20140131.gif
Old Jan 31, 2014 | 05:48 PM
  #859
WannaRace's Avatar
Thank you. Those were my plans exactly. Just wanted to confirm if there were going to be any adverse effects of having the larger port on the PCV side. I have the Kiggly HLA so I can just monitor the can closely.
Old Jan 31, 2014 | 05:59 PM
  #860
mrfred's Avatar
As long as an OEM PCV valve is used in the location I show, there will be no adverse effects of this layout. Also, the check valve needs to have the lowest possible crack pressure. I mentioned Boomba because I have one, and have found it to have a low crack pressure.
Old Jan 31, 2014 | 06:02 PM
  #861
evoxsi's Avatar
i disconnected my intake line from the valve cover,
with a 35r i was pulling enough oil even with the kiggly hla to see it puddle in the intake pipe before the turbo.
Old Feb 12, 2014 | 01:28 AM
  #862
jason42003's Avatar
Mrfred so with the latest version of your catchcan setup the vta check valve opens under boost and the pcv closes due to boost and pulling vacuum it's reversed? And with a kiggly hla how quickly is quickly, I'm looking at this for a dd so I don't want to be loosing too much oil because I am passing cars on a long drive. Not trying to argue just understand the dynamics more.
Old Feb 12, 2014 | 07:06 AM
  #863
mrfred's Avatar
Correct.
At this point, I have not noticed any additional oil coming out the rear of the VC under normal driving or WOT straight line.
Old Feb 12, 2014 | 10:44 AM
  #864
jason42003's Avatar
Ok thank you for the quick response, ill have to try this setup when I redo my head.
Old Feb 12, 2014 | 03:07 PM
  #865
pr0phet's Avatar
Mrfred, where did you purchase the Fairclough -10AN adapter? Google didn't yield anything.
Old Feb 12, 2014 | 03:50 PM
  #866
mrfred's Avatar
I think there is a link in this thread. Try searching on Fairclough in EvoM.
Old Feb 12, 2014 | 04:38 PM
  #867
michaelrc51's Avatar
STM now sells one. Not sure if it is Fairclough's but they sell one.
Old Feb 12, 2014 | 05:27 PM
  #868
pr0phet's Avatar
Awesome thanks - found it. FWIW my scooby doo detective work uncovered that Fairclough is user name here on the EVOM boards who had sold them in the past. Case closed Shaggy.
Old Feb 13, 2014 | 05:10 PM
  #869
TheBigD's Avatar
http://www.streettunedmotorsports.co...er_fitting.htm
anyone try this -12 fitting for the plugged hole when you delete your balance shafts? i just ordered one, and am going to try it out. but i cant seem to find any info on it here
Old Feb 14, 2014 | 02:28 PM
  #870
So, from what I gather from the FP posts and there link it looks like they are running 2, -10AN lines from the VC to a sealed catch can and a -10AN line from catch can to air intake. Although the post that Michael from FP made says he made a "custom vent from the block" ......so maybe I am wrong.
So, any guesses as to how the PCV and/or check valves are run in their setup?
