New BW EFR Turbo Thread
Old Jan 2, 2014 | 07:43 PM
  #2611
211Ratsbud's Avatar
Is there only one mft turbine in he efr line up? 7163
I do like t4 iwg..
Old Jan 3, 2014 | 08:23 AM
  #2612
03whitegsr's Avatar
Originally Posted by mrfred
Just wanted to be sure that we are on the same page. That paper was written by people at IHI, so the BW folks might differ in opinion on whether the use of gamma-TiAl necessitates a turbine wheel efficiency penalty to make the wheel sufficiently robust.
I feel like I'm in an endless loop right now...
Originally Posted by 03whitegsr
Great journal article. While I don't have a Garrett equivalent article, I would bet they came to the same conclusions on the TiAl turbine wheels. Just based on a post I read from a Garrett guy that is on here anyway. Although, it is worth considering the TiAl wheel only lost out because of an assumed 5% reduction in thermal efficiency due to a compromised blade design to make it more robust to deal with FO impacts. There might be some flex room in there to make the TiAl slightly less robust without taking such a big hit on thermal efficiency. Even then though, it seems like you are just compromising reliability for minor gains that could easily be lost with simply an improper turbine to compressor wheel match up.
Getting back to MFT design for a second, one interesting aspect of that paper is an obvious difference in wheel shape (Figure 2) where the MFT appears more suited to make better use of axial flow, while this picture from FR comparing an EFR MFT to an EFR RFT shows no obvious difference in fin design apart from the extended tips on the MFT.
I would say it is best to not call this an extended tip wheel as that is not what's going on. Also the difference in aero design is really minimal and I don't think it's something you are easily going to see with the naked eye in a picture on the internet. This isn't like comparing a 1970s T4 P-trim to a modern GT series turbine wheel where the differences are stark. Both wheels have undergone computational optimization for aerodynamic and structural superiority.
That said, the differences shown in figure 2 may not apply on the TiAL BW wheel due to manufacturing constraints. Or the more simple explanation, that's not an actual mixed flow turbine wheel in the picture you posted. Due to timing, they may have simply cut a normal wheel down for demonstrational purposes to show the main difference before an actual production piece was available. I do agree that it doesn't look like the ideal mft by IHI's article... but as already mentioned, IHI and BW could have different criteria to determine "ideal."
Old Jan 3, 2014 | 10:20 AM
  #2613
RWD4G63's Avatar
Are the EFRs proving reliable? There are only a very few evos running them. What communities are pushing the EFR turbos hard at this point?
The time attack guys are really jumping on them. Nemo and the FX Motorsports NSX now run EFR's. I've seen several Subaru results threads, and even this thread has quite a few results in it. Even the ultra-cheapo drift car guys are buying them now haha.
I agree not all of them are "pushing them hard" at this point, but I haven't read of any more failures since the parts source switch.
Some good shots of the turbo in here:
Old Jan 3, 2014 | 10:50 AM
  #2614
03whitegsr's Avatar
I imagine the next year will probably help as I know they are starting to get more of them shipped out. I bet a lot are sitting on a shelf though while the car is in the middle of some never ending build.
Maybe there is something to the PTE stuff in that they fit just like the older Garrett stuff so people can drop them right into old turbo kits with minimal down time. Even the gtx stuff often can not be used in place of a non gt series Garrett turbo in older turbo kits...
Old Jan 3, 2014 | 11:13 AM
  #2615
RWD4G63's Avatar
Yeah.
But that's almost a different market niche. I'd say most people in the market for EFR's or GTX's want the best system available, and are willing to upgrade. PTE's are cheap enough and hyped enough where people want to adapt them to old kits. Does that make sense? I don't know, that's just my two cents.
Needless to say, I would really really love to experience a twin-scroll 7163 on a 4G or other 2.0liter that had a transmission strong enough to handle the torque load.
Old Jan 3, 2014 | 02:33 PM
  #2616
mrfred's Avatar
That's what I have on order.
Old Jan 3, 2014 | 07:05 PM
  #2617
RWD4G63's Avatar
Awesome! Definitely have to let us know how it goes.
Old Jan 3, 2014 | 10:27 PM
  #2618
khmerpimpin's Avatar
I would like to hear some HTA Green vs EFR impressions!
Old Jan 6, 2014 | 09:15 AM
  #2619
03whitegsr's Avatar
Yeah, I think a 2.3L with a TS 7163 or GTX3071R would be about the ideal setup for a street car. Use ecu controlled boost to keep the torque spike in check then add some boost as VE drops. V8 like torque and response and 500+ hp out to 8500rpm. Yes please.
Old Jan 6, 2014 | 10:12 AM
  #2620
mrfred's Avatar
I have a feeling its going to be at least another month before I get it, and even that might be wishful thinking.
Old Jan 6, 2014 | 12:26 PM
  #2621
uvambo's Avatar
^ did u get the full race kit? Top mount internal gates?
Old Jan 6, 2014 | 12:59 PM
  #2622
94AWDcoupe's Avatar
I want to see results on the 7163 as well. I will likely pick one up if it can make 525 without having to over spin.
Old Jan 6, 2014 | 01:08 PM
  #2623
mrfred's Avatar
Yes IWG. Probably going to have English Racing build all the supporting parts. Trying to avoid having the swap out the radiator that is required with the FR kit.
My goal is full boost by 3700 rpm in 3rd gear and 530-540 whp.
Old Jan 6, 2014 | 02:33 PM
  #2624
94AWDcoupe's Avatar
I was going to get this and have local built short runner mani.
4 cylinder divided t4 cast stainless steel merge collector
http://www.ebay.com/itm/110993363686...84.m1423.l2649
Old Jan 6, 2014 | 05:22 PM
  #2625
mrfred's Avatar
I like that collector. Seems like it will save a bunch of effort for building a manifold.
All the EFR turbos are very long. While the dimensional specs on the 7163 have yet to be released, the TS T4 IWG version will likely be 10" end-to-end just like the 6758. I'm pretty sure that wont fit in a bottom mount configuration, even with the turbo tilted a bit to try to make room for the DP. The TS T4 EWG will probably be 8.5". Since FR has been able to do a bottom mount with the 7670 and 8374 EWG, should be even easier to do this one in bottom mount.
