New BW EFR Turbo Thread
Old Sep 22, 2014 | 04:27 PM
  #2746
mrfred's Avatar
The EFR should have better transient response because of the TiAl turbine wheel.
Old Sep 22, 2014 | 09:39 PM
  #2747
Grimgrak's Avatar
Pics of dp installed?
Originally Posted by PrimerSdime
I'm using aem series 2.
Yes, to install the 3.5" downpipe the a/c compressor had to be removed. The 3.5" downpipe has a very big smooth bend. The 3"downpipe had a very abrupt sharp bend to clear the a/c compressor. The 3.5" downpipe reduces down to 3" before it connects to the exhaust, I just wanted the bend to be in 3.5".
Old Oct 2, 2014 | 10:27 AM
  #2748
R/TErnie's Avatar
Originally Posted by Dragracer187
If I compare the dyno from the 9180 to the Precision 7175 on also a 2.2 engine, the precision looks like the much better turbo. Similar spool but from 5500 rpm it kills the 9180.
would be nice to see them boost for boost... and it would be nice to see a log of transient response T90 times. I think you'd be shocked.
Comparing a turbo at 51lbs to a turbo at 41lbs isn't exactly fair... but I understand the point of the comparison.
Old Oct 2, 2014 | 10:30 AM
  #2749
R/TErnie's Avatar
Originally Posted by URQaudiguy
The 7163 should be compared to a HTA3076r or GTX3076r for overall power potential on .82 AR. Spool on a dyno is almost identical to these two garrett options, but transient is much better due to a turbine that isn't a turd and undersized. Not a knock on FP, as their compressors work well.
I really would love to see a hypothetical 68lb/min 59mm 7670 revamped with mixed flow and put into a vband in/out b1 frame. I am aware of the reasons it can't right now(mainly housing meat and turbine length), but the IWG 7163 packages really nicely in very tight places, like behind the motor on a Audi TTRS. It would be nice to have an upgrade path above the 7163
you guys need someone to tune that TT-RS engine for you?
Old Oct 2, 2014 | 10:34 AM
  #2750
PrimerSdime's Avatar
Like I said, my car spools much faster on the street. The dynojet just doesn't put enough load on the engine. I was looking at some datalogs the other day and iirc my car makes 30 psi at 4500 rpm. My friend has a 2.0L evo with a 6262 on it and my car is more responsive than his.
Old Oct 3, 2014 | 02:14 PM
  #2751
Talonboost's Avatar
If I compare the dyno from the 9180 to the Precision 7175 on also a 2.2 engine ......
Just to be clear, the 2 dyno runs shown in post #2742 (and again in post #2748) - those runs are all PTE 7175, right? (at 2 different boost levels). And the BW 9180 you compare to is the run shown in post 2729?
Dragracer, what turbine housing are you using on the 7175?
Old Oct 16, 2014 | 01:47 PM
  #2752
RWD4G63's Avatar
According to my supplier, 1.45 turbine housings are now available.
Old Oct 16, 2014 | 03:13 PM
  #2753
JohnBradley's Avatar
Actually those runs are a single scroll 6466 maxxed out and cant make more power or boost and then the faster spooling 7175 making more power at obviously more boost.
That wasnt a 9180 comparison in the slightest. There will be no datalogs from either car supplied. Both were SLR2.2 Evo 8s and not a LR2.4 like Martin's car (8374 elsewhere in the thread). His is supposed to be getting a 1.45 9180 so we'll have some data but still nothing I feel I can compare that will be apples to apples.
Old Oct 17, 2014 | 05:19 PM
  #2754
URQaudiguy's Avatar
Not for our kits, but we do have some APR kits that need revisions so they can get through a whole track weekend without limp mode and codes for overboost.
Cheers
Hank
Old Oct 31, 2014 | 10:39 PM
  #2755
URQaudiguy's Avatar
Here is some EFR8374 1.05 TS data on a 2.5L Audi 5 cylinder. Flow on head is roughly 280cfm/220ex. It has a SP QSV spool valve installed. It is spooling pretty quickly on our Land and Sea AWD dyno, and using ~6300cc/min worth of fuel at .81 lambda Air/Fuel on e85. We will be turning it up to around 35psi in the coming days and we will spin to 8500. We are still breaking the motor in and sorting some issues.. Overall, pretty good results for only 25psi.
Last edited by URQaudiguy; Oct 31, 2014 at 10:46 PM. Reason: Everyone likes more pictures
Old Nov 11, 2014 | 12:42 AM
  #2756
project_skyline's Avatar
I'd like to get a 9180, if you find people with turbos or want to use mine for back to back testing I'll gladly volunteer it or my car or both haha!
Old Nov 15, 2014 | 08:28 PM
  #2757
uvambo's Avatar
Got this little guy in(9180 with 1.45AR) we pushed the 8374 more than most, and plan on seeing what this will do, spool, transient, and power. Should have some results soon.
Martin
Attached Thumbnails New BW EFR Turbo Thread-1031141340a.jpg   New BW EFR Turbo Thread-1031141342d.jpg   New BW EFR Turbo Thread-1031141340.jpg
Old Nov 16, 2014 | 07:43 AM
  #2758
mrfred's Avatar
Finally let the cat out of the bag...
Old Nov 16, 2014 | 11:31 AM
  #2759
droppinbottom's Avatar
Martin
When is it going in? Have yet to go for a ride with you.
Old Nov 16, 2014 | 03:35 PM
  #2760
Grimgrak's Avatar
Time to bust out the grinder with the 1.45
