EVO 11.5 Hotside, anybody try it?
Old Jun 30, 2011 | 08:17 PM
  #181
mrfred's Avatar
Originally Posted by wshihdnevo
Yeah its from the same vendor Im assuming. Just with a bigger 2.8" outlet and a flat flange like the dsm's are. The sole reason I bought it is b/c its 3" O/D
what dp do you plan to use?
Old Jun 30, 2011 | 08:30 PM
  #182
warp9's Avatar
Got this today, quality is pretty spot on, just got to port out the outlet to a true 3":
The housing was out of stock so they drop shipped it to me from the vendor, which was nice of them! I should see the housing prob by Tuesday and will post up pics!
There's no divider wall ?... That is not gonna perform well
Old Jun 30, 2011 | 08:38 PM
  #183
06MREvo's Avatar
I was thinking the same thing...gonna be a bit of turbulence in there...I see some boost creep issues in your future...
Old Jun 30, 2011 | 08:55 PM
  #184
warp9's Avatar
Its hard to tell, but I dont see a divider in the Titek v2 in this pic. All the testing that BR did and none of the un-divided ones did well. I guess theres only one way to find out
Old Jun 30, 2011 | 08:58 PM
  #185
mrfred's Avatar
nah. when i switched from stock o2 to the titek v2. i had to crank up the wga preload by quite a bit to hold the same boost. i do worry a bit about turbulence affecting the turbine flow though.
Old Jun 30, 2011 | 09:40 PM
  #186
nightwalker's Avatar
The Invidia doesn't have a divider wall, and it has been a proven performer.
Old Jun 30, 2011 | 09:56 PM
  #187
wshihdnevo's Avatar
I have a custom 3.5" ETS O2 back exhaust.
I'm not too worried about the turbulence. Should work just fine.
Old Jul 1, 2011 | 12:06 PM
  #188
wshihdnevo's Avatar
Didnt expect it to come in today, but it did!!! It looks like it could be ported, but Id like to test it as is. Enjoy!
Old Jul 1, 2011 | 12:09 PM
  #189
Erik@MIL.SPEC's Avatar
NOW this thread is going somewhere
Old Jul 1, 2011 | 12:15 PM
  #190
06MREvo's Avatar
I say port it if it can be! Silly not to...haha...
Old Jul 1, 2011 | 12:30 PM
  #191
D Grade's Avatar
I think the turbulence issue might be slightly over analyzed here. When I put down 375whp on pump, I was still running my Megan 02 housing. Upon removing it to install a dump, I looked at the inside and realized how restrictive it was. Yeah it was divided, but the WG passage to recirc back into the exhaust stream was minimal to say the least.
You'll always gain more HP and have better boost management with an external dump over an internal, but not to the point where its not practical to use an internal. Externally dumped WG's aren't for everyone.
BTW, the housing looks great. Can't wait to see the results on this.
Old Jul 1, 2011 | 12:51 PM
  #192
wshihdnevo's Avatar
I just need to get this O2 housing Outlet matched to 3" and then I will get started on this.
Old Jul 1, 2011 | 01:34 PM
  #193
_des_'s Avatar
Get to it! I'm also interested in this as well.
Old Jul 1, 2011 | 01:35 PM
  #194
wshihdnevo's Avatar
Someone had too!
Old Jul 1, 2011 | 01:36 PM
  #195
D Grade's Avatar
Hurry up, don't make me swing by Tacoma!
