EVO 11.5 Hotside, anybody try it?
Old Jul 27, 2011 | 01:16 PM
  #241
06EvoIXmr07's Avatar
Off topic but are any you guys selling your 10.5 Hotside??
Old Jul 27, 2011 | 01:25 PM
  #242
wshihdnevo's Avatar
Yes, I wil be selling mine. Pm me if interested.
Old Jul 27, 2011 | 01:57 PM
  #243
211Ratsbud's Avatar
If there is an increase in lag I bet its small. Increase in top end.probably small too. Midrange is my guess on peak gain
Old Jul 27, 2011 | 02:07 PM
  #244
Fast_Freddie's Avatar
Veteran: Navy
Ramses, hurry up and get some results out there... I am waiting on this before I drop the hammer on one of these...
Old Jul 27, 2011 | 03:12 PM
  #245
wshihdnevo's Avatar
Plan is to start on it Friday after work for an hour and finish Saturday. I may install my new intake manifold too as I just dont have a ton of time to install the housing and test it and then throw the intake manifold and test it, but we'll see how far I get. Turbine is def going on first, then to Aaron @ ER. Had issues with the wga last time at the dyno, but made 350 @ 20psi on my current setup and before that 385 @ 28psi on a bone stock exhaust manifold and QTP O2 dump. So we'll see.
Old Jul 27, 2011 | 05:42 PM
  #246
sparky's Avatar
Ramses, are you experiencing any taper on your IX turbo in its present configuration with the 10.5 hsg.? If you are, I'll bet it's a small amount. Is the 10.5 on your IX turbo ported, or unported?
Old Jul 27, 2011 | 05:50 PM
  #247
wshihdnevo's Avatar
Yeah I get some taper even with the 25 psi wga. Its a ported Buschur housing.
Old Jul 27, 2011 | 06:02 PM
  #248
211Ratsbud's Avatar
When you say 385@ 28 psi its not like the turbo was boosting 28 @ your peak hp. This is especially deceiving withstock turbo which can boost more in the midrange. Do I sound correct? My peak hp numbers did not increase as boost went up from 22 to 26 but tq did increase and area under the curve.. So what would be the psi at peak hp if your boost was hitting 28 mid ?
Old Jul 27, 2011 | 06:45 PM
  #249
wshihdnevo's Avatar
I'd have to have Aaron pull up the dyno sheet. Couldn't tell you off the top of my head what it was out the top.
Old Jul 28, 2011 | 05:02 PM
  #250
Guerillah's Avatar
I just bought one... Broke a stud in my housing and too lazy to get it out, figured i'd try this out. Anyone try out the ebay upgraded wastegate actuators?
Old Jul 28, 2011 | 07:18 PM
  #251
211Ratsbud's Avatar
Arrrr... I may go with the 71hta upgrade depending.. Its super reasonable for power lol.
Old Jul 29, 2011 | 01:52 AM
  #252
rileyschroeder's Avatar
Looking to see what kind of power you get out of this!
Old Jul 29, 2011 | 06:34 AM
  #253
BigT's Avatar
Well that is not a true comparison if you will be changing your intake manifold at the same time.
Old Jul 29, 2011 | 09:18 AM
  #254
wshihdnevo's Avatar
I'm assumng this was directed towards me. I could care less if it's not a true comparison, but depending on time the intake manifold may not go on. I don't have the time or money to test them like I want so we'll see. More than likely I won't have time to install the intake, but if all goes well I may. I don't really want to, but I need to otherwise it will go on 2 weeks from now.
Old Jul 29, 2011 | 09:30 AM
  #255
BigT's Avatar
Ok, thanks for letting us know that you will have almost nothing to add to this thread.
Waste of 17 pages.
