EVO 11.5 Hotside, anybody try it?
Old Jul 30, 2011 | 03:19 PM
  #271
3gEclipseTurbo's Avatar
Nice sig edit lol
Old Jul 30, 2011 | 04:05 PM
  #272
wshihdnevo's Avatar
Originally Posted by 3gEclipseTurbo
Nice sig edit lol
Thanks
Old Jul 31, 2011 | 06:41 AM
  #273
sparky's Avatar
How is testing a ported 10.5hs vs a non-ported 11.5hs fair?
Unless the 10.5 housing was extensively ported there really shouldn't be that big of a difference powerwise between a ported and nonported stock housing. The difference is slight and could be fudged out depending on the skill of the tuner.
Most porting jobs offered currently are actually pretty mild. There is a gasket match which is blended down into the turbine inlet area about an inch. Also, some jobs open up the turbine discharge area removing the overhanging lip in the casting at the exit area just beyond the turbine wheel's exducer.
Old Jul 31, 2011 | 12:30 PM
  #274
Thats why I do all my own port work and I "extremely" ported my 9.8hs. I actualy removed alot of material not just polish it.
Old Jul 31, 2011 | 01:28 PM
  #275
211Ratsbud's Avatar
Anyone ever put a 9.8 on a ix turbo ? Curious..
Old Jul 31, 2011 | 02:25 PM
  #276
wshihdnevo's Avatar
A few years ago we swapped one on to a friends car b/c his 10.5 got stripped out. He didn't really lose any power. This was on a IX. The car was tuned by Aaron @ ER.
Old Jul 31, 2011 | 03:03 PM
  #277
211Ratsbud's Avatar
Boost threshold change at all?
Old Jul 31, 2011 | 03:53 PM
  #278
wshihdnevo's Avatar
Not sure. I was at the dyno after we finished the install, but its been too long since then. Aaron would have to comment if he remembers or has the dyno plot or logs, which Im sure he does.
Old Jul 31, 2011 | 04:09 PM
  #279
211Ratsbud's Avatar
Figure it might be a good reference ya know?
Old Aug 1, 2011 | 03:37 PM
  #280
211Ratsbud's Avatar
Found out today my turbo was an older billet wheel white rabbit with a clipped turbine wheel... Sigh.. 71hta here I come with 11.5 and fap
Old Aug 2, 2011 | 09:49 AM
  #281
Aby@MIL.SPEC's Avatar
wshihdnevo, So what are your initial impressions? city driving / on-throttle boost ramp up stuff?
Was your previous hotside ported? is your exh mani ported?
what w/g actuator ware you running?
any idea when you might get back on the rollers?
Old Aug 2, 2011 | 10:07 AM
  #282
wshihdnevo's Avatar
Initial impressions are great! Feels good, pulls hard up top even at 20 psi. I'm having some boost issues which I'm sorting out. Not sure yet what the issue is. Seems to spool just as quick. Previous hotside was a Buschur coated/ported and I run the Shearer header. Wga is Fp 25 psi. Not sure when I will be back on the rollers. ER is pretty busy. Might have to see if I can just get on another DJ local, but I'd like to test it on the same DJ I always use which is ER.
Old Aug 2, 2011 | 10:27 AM
  #283
Go ER!
Old Aug 2, 2011 | 03:11 PM
  #284
Guerillah's Avatar
What kind of boost control problems you having?
Old Aug 2, 2011 | 03:22 PM
  #285
Guerillah's Avatar
I ask because I just received my 11.5 housing and the puck comes out quite a bit from the housing, I am wondering if it will have interference issues with O2 housings. .
Another thing I noticed, it has A3N cast on the housing. A little research turned this up....
http://www.cbmm.com.br/portug/source...s/pdfs/053.pdf
