Kinugawa 25g turbo thread
Old Oct 16, 2013 | 12:21 PM
  #706
MyronGainz's Avatar
Im sure someone else will confirm, but to save you the hassle of finding out yourself, I'm pretty sure the turbine wheel won't fit the standard 10.5 housing
Old Oct 17, 2013 | 09:25 AM
  #707
evoiao's Avatar
Originally Posted by damien666
Had turbo off today and it appears that the flapper is not sealing properly i can press it down and move sideward by hand only slughtly but enough to create issues id say also theres fair bit of play thrust as can prettymuch make the wheel hit housing, so will get a kinugawa rebuild kit and maybe use my standard exhaust housing?
Hi I have a BNIB kinugaw 11.5 hotside..never used...it was made for the 25g its polished by kinugawa as well.
Pm and ill give you a very fair price.
Old Oct 25, 2013 | 12:04 AM
  #708
TJung's Avatar
Hey guys. I have an Evo 7 with stock motor and I am considering TD06-20G or TD06-25G. Normal cover or Anti surge? I am not sure which should I choose for my DD Evo.
Also I wish to know how to repair possible problem with WG. What is the problem with it? Too thin material of flapper or something else?
Old Oct 26, 2013 | 07:35 AM
  #709
damien666's Avatar
Guys i still have my td05-hra-16g evo 7rs turbo now can i put the kinugawa turbo 20g comp wheel cover on that
Old Oct 27, 2013 | 07:33 PM
  #710
Zee Biker's Avatar
Sad to see these fall so short of the mark; the price is really right.
Old Oct 28, 2013 | 03:26 AM
  #711
WikdEvo's Avatar
What mark?
Old Oct 28, 2013 | 08:48 AM
  #712
MyronGainz's Avatar
Originally Posted by Tom Stout
What mark?
My sentiments exactly?
Old Oct 28, 2013 | 02:22 PM
  #713
VIIIdriver's Avatar
Plenty of then running reliably for quite some time and making expensive turbo power, so if you have a point from personal experience why not make it, right ?
Old Oct 28, 2013 | 02:27 PM
  #714
Zee Biker's Avatar
I would say that everyone needing extensive work to get this to make boost is pretty suspect. Between new springs in the wastegate to having to cut and reweld the arm and that not being correcting it every time, that's a large red flag. And running an external in place of the 02 dump is pretty fantastical.
Have the cover crack/burn through/fail in any way is pretty frightening.
Spool is slow (looking at where these make 300wtq, the boost curve is even worse).
Peak power is nothing out of this world either.
Now, before you say anything about me being poisoned against the brand, know that I am looking HARD at buying a Kinugawa turbo for my personal subaru. Different platform, different goals, different turbo.
Old Oct 28, 2013 | 10:14 PM
  #715
TJung's Avatar
Can someone help?
Old Oct 29, 2013 | 04:34 AM
  #716
WikdEvo's Avatar
The answers are in this thread
Old Oct 29, 2013 | 09:25 AM
  #717
TJung's Avatar
Its not easy to find them on almost 50 sites. Thanks
Old Oct 29, 2013 | 09:42 AM
  #718
WikdEvo's Avatar
I did it. That's what this thread is for. Grab a beer and a snack and start reading.
Old Nov 1, 2013 | 11:30 PM
  #719
evoiao's Avatar
Throw him a bone ....
Old Nov 3, 2013 | 03:01 PM
  #720
SANDIEGOSFINEST's Avatar
just seen the vid Tom Stout! great numbers man. I responded too the vid with a few questions but found the answer too one of them. seems those were on 34psi pulls. my othef question was which turbine wheel and housing were u using? the SL2r or 06HR? also, what compressor wheel are u using? cast, billet, dual 5 or 6 bladed?
I had posted my results I had made a few pages back. I have still yet too do anything new too the car :-( but soon ill have her out again. It seems you are the dyno king with the most outta these turbos along with VIII Driver and myself right behind you. im plenty happy with what I made a couple months ago. ahit, for auch moderate boost and tune unfinished, 527@23 psi isnt bad in my book. I am in a fwd car so I understand theres that advantage there but for what it is, ima happy camper lol
