Bad Bish, the next generation-introducing the clutchless 4 speed.
Old Mar 16, 2012 | 11:38 AM
  #91
metalsaber's Avatar
Originally Posted by EVOlunchbox
BTW: I cracked up after reading how Dan reacted/what he said. I can see him saying that calmly. LOL
same
Old Mar 16, 2012 | 11:50 AM
  #92
David Buschur's Avatar
No on the reverse manual. No on the trans brake, it would destroy the trans instantly and the rest of the car.
  #93
Update on the breakage. Got the trans apart and it's worse than we thought. The planetary exploded. We aren't sure what went first there is a LOT of damage, pictures are on our Facebook page of the exploded parts.
I have an idea what happened but I am not expert. I don't believe these parts could fail this quickly, so I'm hoping the simplest solution is the one that will work. Other wise it's going to be costly to fix.
Vinny, my trans guy wants me to put the trans back in and turn the power way down to just drive it. I'm thinking I may do that and build a stock turbo kit to fit with it. When we tore the trans down we did get some good news too. The clutches/steels/hub/piston etc., etc., that we built before even getting started on this all worked out perfect. NO signs of any slippage at all so we are very happy with that.
As for the time frame question, I don't know at this point. I'd like to make all new parts for what we just broke, not going to be cheap, easy or fast.
Old Mar 16, 2012 | 11:56 AM
  #94
brokenRS's Avatar
Off topic, BR do you always put on a new FMIC? or how do you keep yours looking good in such condition. haha.
Old Mar 16, 2012 | 12:11 PM
  #95
03whitegsr's Avatar
It would be interesting to figure out the alloy used and heat treatment on those parts that broke. Looks like a lot of the pieces might not be able to be beefed up due to interfacing with other parts/space constraints in the case?
Old Mar 16, 2012 | 01:30 PM
  #96
Hahaah! I do wash them but this one is the new design we just built.
Old Mar 16, 2012 | 01:31 PM
  #97
That is what we are going to do first actually, probably next Thursday. There are other options like straight cut gears too. I do not want to give up on this!
Old Mar 16, 2012 | 03:35 PM
  #98
Don Q's Avatar
DB,
I was wondering if there was any lag between shifts like some automatics feel or did it felt like a manual transmission tha once you move the stick into gear and release the clutch its on gear?
  #99
tscompusa's Avatar
very nice.. hope it gets figured out. definitely a lot of new records will be set if it does.
Old Mar 16, 2012 | 05:15 PM
  #100
Originally Posted by Don Q
DB,
No lag at all, it is instant. That part of it is attributed to Andrew, he did the wiring that I currently have in the car that actually controls the shift. It's supplied in a top secret sealed box called the "Magic box"!
Old Mar 16, 2012 | 05:44 PM
  #101
Don Q's Avatar
Awesome
Old Mar 18, 2012 | 04:40 AM
  #102
EVILutionVIII's Avatar
Veteran: Air Force
What a story!! Good luck on the rebuild and can't wait to hear how this turns out.
Old Mar 18, 2012 | 09:32 AM
  #103
48mile's Avatar
i know this sounds counter productive, but would setting the clutch packs to have some slip be easier on the planeterys, assuming the planetarys can't be improved, without using unobtanium materials? Great right up any way. Hope to see this go further without to many more headaches
Old Mar 18, 2012 | 04:19 PM
  #104
We can improve the planetarys I'm sure, what it will cost or the time it's going to take is another story. Going to look into it this week.
Old Mar 18, 2012 | 04:46 PM
  #105
EVOMIZ's Avatar
great build can't wait to see it make a pass.
I have owed 6 dsm's and the automatic dsm was by far the scariest, non stop boost till you let up
