View Poll Results: Which Intake
HKS
150
42.25%
AEM
40
11.27%
K&N
56
15.77%
Others
109
30.70%
Voters: 355. You may not vote on this poll
Intake Evo 8
Old Sep 10, 2004 | 05:08 PM
  #61
4DR4WD's Avatar
Originally Posted by airtreking
Guys, check this thread out....
https://www.evolutionm.net/forums/sh...threadid=82047
The graphs show a 11whp gain for the HKS RS suction kit compared to stock box with a K&N drop in....
made 11whp on a MODDED evo.
Originally Posted by DynoFlash
Here is some very interesting data
Here is a customer who came in with 3" exhuast, walboro pump, boost controller and he had the HKS RS suction kit on May 7
Apparently the customer could NOT stand the sound of the stock bov which was much louder through the HKS RS kit so he came back with his stock intake and K & N drop in filter 11 days later with the same exact mods expect the HKS RS intake
You can see that the car lost like 11 whp and 4 ft lbs of trq
Old Sep 10, 2004 | 07:27 PM
  #62
xxxevo8xxx's Avatar
A cotton filter (K&N) flows way better than the foam style (HKS). I had a AEM intake on my evo and fit very bad. The next AEM intake that i got and installed on a customers car fit great. The AEM intake is a pain to install becuase the piece that slides over the MAF is way to small. I just put a Typhoon intake on my car. The fit & finish is great. The performance part is bad. The best setup up I have used so far is the stock intake pipe, with the AEM adapter plate & filter. This setup works the best.
Old Sep 11, 2004 | 06:00 PM
  #63
TampaTurbo's Avatar
Wink
If you plan on doing future upgrade you may not want to go with a drop in filter and spend the extra money on an intake. Some other after market parts require the extra room from removing the stock air box. What everyone should do but probably doesnt is map out everything you want on the car first to make sure it will all bolt up together nicely versus having a frankenstein like car which requires modification to parts after they have been purchased. I am a perfect example. If you want to go with a buschur IC setup, then do not buy the KN Typhoon as I already had to cut/chop the CF heat shield. I needed to do this after I installed the small battery kit. Its pretty worthless now so I have removed the CF shield. Again, dont buy a BOV unless you would be happy with the 1G crushed that comes with BRs upper IC pipe. They will modify it for you to work with an aftermarket BOV, but it makes for more twisting/tweaking etc. Anyway, good luck at whatever your goals are.
Old Sep 11, 2004 | 06:45 PM
  #64
evo8MR's Avatar
my brother had the k&n typhoon and after installing it his car it was much slower. He then got it tuned and it was pretty sick but just doing the intake with some exhaust stuff made his car probably slower than a stock evo without tune. Also he said that when it rained or he washed his car the filter would be wet, he said he wouldnt get it again.
Old Sep 11, 2004 | 09:58 PM
  #65
Ted B's Avatar
I've decided not to fiddle with the aftermarket intake setups. I did order this however, and we'll see what happens...
http://store.vividracing.com/catalog...4d571a2a26545e
I'm hoping that it makes the intake a bit louder without altering the quality of air flow through the MAF (which upsets tuning).
Old Oct 2, 2004 | 12:41 PM
  #66
Dynofrk666's Avatar
I have the AEM intake and i defiantly noticed a loss of power when I installed it. The sound of the turbo and the bov was nice though. I went back to stock seeing as i would rather have the power over the sound.
Old Oct 2, 2004 | 02:24 PM
  #67
mphevo's Avatar
What is a MAS?
What is a MAF?
MAS stands for mass airflow sensor. It is also sometimes called MAF, for mass air flow sensor. It is the assembly that measures the properties of the air entering the engine, consisting of three separate sensors.
Old Oct 3, 2004 | 07:50 PM
  #68
sleet's Avatar
HKS rs intake !
Old Oct 12, 2004 | 02:17 PM
  #69
gofaster87's Avatar
Damn $140 for a cover. Looks good though but you could have probably made a nice one yourself.
Old Oct 12, 2004 | 02:29 PM
  #70
mphevo's Avatar
vividracing...
well he did get it form vivid...
Old Oct 12, 2004 | 07:45 PM
  #71
evoviiitx's Avatar
I just got a greddy type s bov but I am not sure how adjust it properly
Old Oct 14, 2004 | 12:48 PM
  #72
4DR4WD's Avatar
you spent 140 bux on that!?
someone could have easily fabricated that idea for you, FOR A LOT CHEAPER!
Old Oct 14, 2004 | 10:57 PM
  #73
evoRS04's Avatar
Ebay Filter W/ Adapter!
Old Oct 15, 2004 | 12:45 PM
  #74
6one9EVO's Avatar
K&N intake...loud spool up
Old Oct 15, 2004 | 08:53 PM
  #75
Ted B's Avatar
Actually, I reconsidered and cancelled the order. Ah well!
