How to build a 4G64 for an EVO 8/9
Old Jun 4, 2013 | 05:47 AM
  #136
bigdnno98's Avatar
Do I need to worry about valve clearance with my Kelford 272s? My head was machined when I blew the head gasket cause it was warped. The block decked. We're using a cometic HG.
Old Jun 4, 2013 | 06:56 AM
  #137
evolve_VIII's Avatar
Originally Posted by bigdnno98
We're using 156mm Manley turbo tuff rods.
The turbo tuff rods are larger on the bottom and the block does require machining to clear. I will add it to the original post.
  #138
ExViTermini's Avatar
Shouldnt as long as your timing is right. I have kelfords as well, head shaved twice, block decked .003. No issues here.
Old Jun 4, 2013 | 06:59 AM
  #139
Should be fine. Im running a stock 8 gasket.
After doing some research, I found that the 2.4L engines love the kelford 280s. I maybe switching to those next year. the 272s dont flow enough air for the 2.4 since it was tested with a 2.0 engine. The 2.4 with the 280s will sound like a 2.0 running 272s.
Old Jun 4, 2013 | 07:28 AM
  #140
bigdnno98's Avatar
Great. Thanks guys. I have a couple potential buyers so I want to make sure it's built correctly.
Old Jun 5, 2013 | 10:19 PM
  #141
sbgtr's Avatar
Awesome thread I've been looking for something like this. Thanks
Old Jun 7, 2013 | 09:53 AM
  #142
92 GSR-4's Avatar
Did anyone do anything "special" to the head in order to make it work?
Buschur's website talks about some special work that has to be done to the combustion chamber in the head in order to work correctly with the 4G64 block.
"The cylinder head will also need work to the combustion chamber to work correctly with this engine. "
https://secure.buschurracing.com/cat...d442d4ae1322a7
Old Jun 7, 2013 | 10:48 AM
  #143
That probably has something to do with the long rods and BR spec pistons.
If you are running the standard 150mm rods, stock crank and pistons, no head work is required. Mine runs fine and nothing hits.
Old Jun 7, 2013 | 12:19 PM
  #144
92 GSR-4's Avatar
I don't think it's because of the LR option. The standard 2.4L has the same message on their website, while the LR 2.0 does not.
Either way, you've answered my question, thanks!
Old Jun 8, 2013 | 07:16 AM
  #145
bigdnno98's Avatar
Well I hope no special beadwork is needed. If I remember correctly BR orings the head. Maybe that's what they're talking about. I had my head machined because it was warped. That's all I've done. My block was decked, bored .020, honed and I'm using long rods and 1400HD pistons with Kelford 272 cams and super tech dual springs and retainers. Fingers crossed it works fine.
Old Jun 8, 2013 | 09:27 AM
  #146
Lexus01IS's Avatar
Heal chambers need to be bored due to bigger bore on block. I just picked up my block and head from Jackson auto machine. I had them rework the chambers to block bore size.
Old Jun 8, 2013 | 12:15 PM
  #147
92 GSR-4's Avatar
Details/pics on this please? I've been fiddling with DSM 4G64's for a while and never heard of this.
Old Jun 8, 2013 | 12:36 PM
  #148
Live4Redline's Avatar
^ I'll second that, have never heard of anything like this and details would be appreciated.
Old Jun 8, 2013 | 06:00 PM
  #149
bigdnno98's Avatar
how many people running 2.4L 4G64 blocks with 4G63 heads did NOT heal the combustion chamber? This is really the first I've heard of this and the damn motor is supposed to go together next week.
Old Jun 8, 2013 | 06:10 PM
  #150
Lexus01IS's Avatar
4G63 is 85mm and my 4G64 is 87mm. I end up getting the head chambers bored out 2mm to match my 4G63 bore. I will take pics of the head tomorrow.
