New FP Green! FP54 57lbs/min
Old Sep 19, 2016 | 05:02 PM
  #316
Balrok's Avatar
It's common sense really. If FP, the largest purchaser of them can't get them because a high up MHI rep told them so, and they sell more then both combined then logic dictates the alternative. History as stated above was well documented by FP, so they'd rather NOT sell a turbo then sell one with parts that fail (well all turbos fail but you understand). I'm not an FP fan boy - by any means. Just making the history and facts clear to those that likely don't know.
To think further, FP spent many $ developing the SS housing - but only for the best selling turbos at the time. The 71 and the 54 both use super small exhaust wheels for quicker spool - thus if you know anything about exhaust housings is an issue when air bleeds past the wheel. Restating the fact that Blacks far outsell Greens and whites(71), whats the business motivation to make the smaller SS housing. Thus why you only get a chra for the 71 and no option for the 54. Yet anyway.
Old Sep 19, 2016 | 08:16 PM
  #317
LetsGetThisDone's Avatar
FP works closely with MHI, hell, the assisted MHI is developing the upgraded 18k turbo for the X. So I think if MHI housing were available, they would have a line on them....lol
Also, the 71hta doesn't just use a small turbine, it's the stock MHI turbine. That turbo is simply a compressor upgrade.
Old Sep 20, 2016 | 06:48 AM
  #318
mrfred's Avatar
Maybe I'll call Blouch to ask.
Old Sep 20, 2016 | 06:54 AM
  #319
Balrok's Avatar
Also, the 71hta doesn't just use a small turbin, it's the stock MHI turbine. That turbo is simply a compressor upgrade.
I didn't know the wheels wore turbin's .
Old Sep 20, 2016 | 07:03 AM
  #320
mrfred's Avatar
Blouch says that they are still using genuine MHI housings. The tech person noted though that the cost to obtain them has gone up considerably. I see no reason to disbelieve. FP is not the oracle of MHI housings. Recall that some time ago, they said there would be no more, and then a year or so later, there were more. And as I said before, the use of Chinese housings is a dicey proposition. It didn't work out for MAP.
Old Sep 20, 2016 | 07:12 AM
  #321
Balrok's Avatar
Agreed, good to know, if anyone has acquired one it would be good to see/verify so we can maybe fanagle something rather then being forced into a particular design.
Old Sep 20, 2016 | 07:28 AM
  #322
nemsin's Avatar
Good to know. I was pretty confident Blouch (and likely Owen Developments as well) would not try to pass off chinese junk. No longer made does not equal no longer available on the market.
Old Sep 30, 2016 | 05:02 AM
  #323
Jmills's Avatar
Tuned last week, still working out some issues (killed front O2 Sensor which had 95k miles on it , IAC
died as well)
*Edit
Green Lines are E85
Red Lines are 93 Oct
Old Sep 30, 2016 | 08:58 AM
  #324
Not sure if that dyno reads like a dynojet, or a mustang dyno, or what fuel your using. But my red makes 280wtq at 4k, and 380wtq at 4500 on a mustang dyno on E85, which very nearly mimics your red torque curve. Except I have a flat torque plateau from 4500-6000 before it falls off. I was expecting the torque to hold so well, but I was also expecting faster spool and the torque to come up earlier with the FP54.
Old Sep 30, 2016 | 09:19 AM
  #325
Jmills's Avatar
Sorry I probably should have given a little more detail.
From what I was told, this should read similar to a Mustang Dyno.
Red lines are E85
Green are 93 Oct
I believe the torque was brought on a little later to keep the block safe, granted I still have to have some items ironed out.
Old Sep 30, 2016 | 09:30 AM
  #326
If you want the block to be safe, I would reel in the ~430wtq number. Keep the line at a flat 390-400. If it reads like a mustang dyno, that's like 46-470wtq on a dynojet. Well above the accepted ~400wtw safety area.
Old Oct 10, 2016 | 12:29 AM
  #327
balls_deep_evo's Avatar
died as well)
*Edit
Green Lines are E85
So glad someone finally put down some numbers on paper. how much boost were you able to run? After all this time we finally have a dyno sheet. Thx hopefully we can get some more with some different set ups soon.
Old Oct 10, 2016 | 04:42 AM
  #328
Jmills's Avatar
I can't remember the boost numbers off hand (I want to say it was 28 PSI on E85 and 24-25 on 93 Oct?). I've been chasing some issues that popped up afterwards and as it turns out my BRAND FREAKING NEW Omni 4 bar Map sensor is crap
I should be getting a new one in today and then the plan in to swap to an AEM 3.5 bar sensor since there seems to be some quality issues with the Omnis now.
Old Oct 10, 2016 | 09:34 AM
  #329
austin46's Avatar
I had to put my set up on the back burner for a few months, but it's finally coming together . Planning on getting it tuned in about 2 weeks.
Though I don't see the turbo on FP's site anymore, so I guess there's probably only a few people left that are worried about seeing the results lol.
Old Oct 10, 2016 | 08:20 PM
  #330
Are you stock block also? im really interested since I have a Mhi jb red too. Ran it on my built 2.0 and it was nasty but changed to a alum 2.2. so wanted to see how the FP54 went to see if I should start looking to acquire one.
