Evo 8 DD, 400whp, best and cheapest clutch?
Old Mar 5, 2018 | 06:11 AM
4G63_Crazy's Avatar
5 Year Member
Hey everyone
So I am going to be upgrading my car soon and I think along with modifications, I might need a new clutch considering that I don't even know how many miles are on my current clutch or what kind it is. So, this car is my daily driver and I'm looking for a cheap (something that won't break the bank) but a nice clutch that can withstand with these mods (I think anywhere between 380-420whp on 93)
-Ets 3" FMIC
-ETS UICP And LICP
-ets intake
-GSC S1 CAMSHAFTS
-hallman pro mbc (might want to turn boost up to 28 PSI)
-greddy TBE
-12500cc FIC injectors
-fp green 73hta
- 255 walbro
-evo 9 BOV
​​​​any opinions are helpful, thanks!
Old Mar 5, 2018 | 06:16 AM
Similar set-up w/my 9 (recently tuned to 459 WHP Dyna Pack)
Been on the ACT HDSS for 5 years & works well. Now, I do not launch but have tracked it many, many times
Old Mar 5, 2018 | 06:41 AM
4G63_Crazy's Avatar
5 Year Member
Have you ever launched it on that clutch? And how many miles have you put on it? Any notice of wear yet?
Old Mar 5, 2018 | 07:32 AM
No, never launched (not a 1/4 miler type guy). Car is set up as a track day car only. Approx 15K on the ACT. Drives like a stocker IMO & is holding up just fine. If i were to build the motor for over 500whp, I would likely consider something more robust (Exedy / Quartermaster etc)
Old Mar 5, 2018 | 07:47 AM
2006EvoIXer's Avatar
Sorry, double posted.
Old Mar 5, 2018 | 07:56 AM
If you are going to upgrade your clutch, do that first (are you going with a lightened flywheel?). I'm a believer of breaking in clutch (like new brakes) to get the most contact surface before launching. After breakin, then upgrade everything else. Do your fuel last since you can't drive it until it is tuned.
You may want to look at a 3-port and let the ECU control boosts based on gear and throughout the RPM range.
Just saw you are only getting tuned for 93. Fuel pump should be good until you go E85. Then you'll need rewiring.
Old Mar 5, 2018 | 11:09 AM
blackline's Avatar
5 Year Member
ACT HDSS or XTSS and you should be good for 500TQ(stated by ACT)
Old Mar 5, 2018 | 12:01 PM
LetsGetThisDone's Avatar
ACT HDSS is all you will need.
Old Mar 5, 2018 | 11:13 PM
codgi's Avatar
Act
Old Mar 6, 2018 | 01:59 PM
Toekneeng's Avatar
ACT HDSS. I daily drive with it sitting at 420whp and it's great, not too heavy and pretty smooth engagement. I've also done about 10 passes/launches and seems to be solid.
saltedevo
Dec 16, 2017 08:16 PM
xx_mne_xx
14
Dec 14, 2015 05:51 AM
Tommygun916
16
Aug 13, 2014 08:39 AM
seahawks12th
41
Jun 15, 2009 01:05 PM
Derek888
30
Nov 29, 2004 05:20 PM
