The Turbokit is out and it's sick
Old Jun 20, 2004 | 12:46 PM
  #256
Az3ar's Avatar
you guys want more??
Attached Thumbnails The Turbokit is out and it's sick-115-1504_img.jpg   The Turbokit is out and it's sick-115-1514_img.jpg   The Turbokit is out and it's sick-115-1530_img.jpg   The Turbokit is out and it's sick-115-1547_img.jpg   The Turbokit is out and it's sick-115-1549_img.jpg
Old Jun 20, 2004 | 12:47 PM
  #257
Az3ar's Avatar
more?
Attached Thumbnails The Turbokit is out and it's sick-115-1553_img.jpg   The Turbokit is out and it's sick-115-1556_img.jpg   The Turbokit is out and it's sick-115-1561_img.jpg   The Turbokit is out and it's sick-115-1568_img.jpg   The Turbokit is out and it's sick-116-1614_img.jpg
Old Jun 20, 2004 | 12:49 PM
  #258
Az3ar's Avatar
ok thats it
Old Jun 20, 2004 | 12:53 PM
  #259
en1gma19's Avatar
looks good man. glad you're happy with it. my personal taste is more along the lines of BIG power, I don't mind a little more lag. That just means I can keep it out of boost to save gas while normal driving. But the kit looks very well made, high quality. Glas everything is finally installed and tuned.
  #260
Az3ar's Avatar
many many thanks to shiv, Tom and every one there it was nothing but a great day. by the way I reached very high speed lets say on the way back today . its amazing how much top end power I have now. the car feels like a big *** V8 after 100 mph and keeps pulling so hard till $%#@$%$#
Old Jun 20, 2004 | 12:55 PM
  #261
Az3ar's Avatar
in 3 moths i will get camgears and the whole nine yards from Shiv. stay tuned for around 350 whp on DD
Old Jun 20, 2004 | 12:56 PM
  #262
Az3ar's Avatar
and ofcours many thanks to Paul from ATP. I know you are reading this post man so come on and say something.
Old Jun 20, 2004 | 02:01 PM
  #263
evotomig's Avatar
Don't forget to change your sig.
Nice meeting you there. Glad you're REALLY enjoying the new set up and be sure to let your buddy hook you up w/ a testpipe. You'll be surprised what a difference that will make in spoolup.
The NorCal Tom
Old Jun 20, 2004 | 02:05 PM
  #264
nastea's Avatar
Originally Posted by shiv@vishnu
Hi guys-- Here's my take on the ATP 3071, fwiw. It does indeed spool up just like the 3037 (also .63)/custom tubular manifold set up I had on our One Lap car. However, it does this with a *stock cat* and not the test pipe that I run. All things equal, I suspect it to have 700-8000rpm spool up advantage to the GT3037 which is really quite good. Also, on our dyno, boost lag tends to be exaggerated due to the way the engine loads up. Well, not really exaggerated... but it comes close to representing the boost lag you feel on the street when you load it up in 3rd gear. If tested with a much slower ramp-up rate (simulating the first 5 or so seconds of a Dynojet pull where the big rollers are slowly getting up to speed), boost response with drop by another 400-600rpm which is where I suspect ATP is getting their sloop up claims. As such, their claim is perfectly valid and the difference in spool up that we are seeing is based mostly on differences in testing methods. Nothing to create a controversy about, IMHO To give you an idea of how different loads and different gears can effect spool up, look at this: In 4th gear, lugging from a low RPM, the big GT35 on my car can reach 20psi by 4500rpm. In 3rd, it takes until just under 5000rpm. In 2nd, it takes until past 5500rpm. So spool up numbers, by themselves, don't explain the whole picture-- especially when dealing with bigger turbos.
And as others pointed out, we'd really love to get a car with cams, gears, test-pipe (or at least a high flow cat), full race gas to test this kit on. But so far, with this car, the results are quite good. We have established that putting a bigger turbo on an EVO without upgrading cams leaves a lot on the table as exhibited by the power roll-off above 6000rpm. Still, the car made plenty of power given the few mods
my 2c,
Shiv
good to know thanks shiv
Old Jun 20, 2004 | 02:10 PM
  #265
ez76's Avatar
az3ar/shiv feel free to post up the final 91.5oct and 97oct dyno charts if you are so inclined
Old Jun 20, 2004 | 02:21 PM
  #266
en1gma19's Avatar
BTW. az3ar.....If you want a test pipe, I've got a B&B test pipe sitting in my garage that I'm not using. if you're interested pm me. I'll give it to you at a good price.
Old Jun 20, 2004 | 03:17 PM
  #267
RENN-ART's Avatar
it seems like the results were exactly as expected... don't know what some people are thinking..
with mods like the high-hp stock turbo guys (cams/cam-gears/big FMIC/testpipe), you'll be in the 400+awhp club for sure! (not DD awhp.. but still)...
Old Jun 20, 2004 | 03:18 PM
  #268
Az3ar's Avatar
en1ma19 thanks man. however. I dont know if it will fit the helix exhaust??? since its huge. Helix has one with out engine check light so I think i will get one from them except if yours fits my exhaust and check engine does not come on. i will post dyno tomorrow as I dont have scanner at home. I just relized that I made about 390 whp on dynojet with 97 gas that means I gained about 390-238=152 whp
Old Jun 20, 2004 | 07:52 PM
  #269
Az3ar's Avatar
Our cars lagged the top end. now I can keep up with V8 engines no problems all the way to 140 - 150 miles and perhapes kill them as I tried today
Old Jun 20, 2004 | 08:34 PM
  #270
RENN-ART's Avatar
for pete's sake, change that signature of yours!
