The Turbokit is out and it's sick
Old Jun 29, 2004 | 07:09 AM
  #466
chuntington101's Avatar
/\/\/\/\ Very good post mate, as i have bin trying to say for a long time on here this guy (EVO 400) is the man. the GT3071 is a good turbo but it is flawed. clipping is not a good idea on modern turbos when we are all striving for less lag. if you want to upgrade then go for a GT28 as they are just as good but better sized. if you really want more then there is the GT2830 which is a wicked combo for 2.0ltrs (just ask Claudis (i think) on www.lancerregister).
just my thoguths but there you go!
thanks Chris!
Old Jun 29, 2004 | 07:14 AM
  #467
Eric Lyublinsky's Avatar
thanks Chris!
Well Chris I would be willing to give it a honest go. We will see if we can work somthing out.
Eric
Old Jun 29, 2004 | 08:15 AM
  #468
Az3ar's Avatar
Originally Posted by bolsen
Don't use that crummy white line. Buy new fittings from a hardware store, and run some black rubber line. Works 100x better and not so cheap.
Yup how did you know that it's a white plastic hose??? It's freaking cheap. You can’t' push it or it snaps off like a *****. I guess I will get something from home depo tonight, I hope they will have a small hose like that. About the engine check light do you think it was because the hose snapped??? I have not touched anything else besides installing the plastic in the bottom. I just can't imagine how sensitive our ECU is????????
Old Jun 29, 2004 | 08:16 AM
  #469
Az3ar's Avatar
thanks Chris!
GT2830 is a great turbo however its a hair bigger than out stocky 16G. It only pumps 50 whp extra so is it worth the money??????
  #470
evo400's Avatar
Registered User
MARK SHEAD @ MAD DEVELOPMENTS HERE IN THE UK WITH THE INTERNAL GATED GT 71MM WHEEL RAN A 393 HP @ THE WHEELS ON A DYNO DYNAMICS ROLLING ROAD . ALSO MANAGED PEAK TRACTIVE EFFORT @ 4600 RPM 2650 UNITS OFF !!!! .
PLEASE NOTE GUYS !!!!!! PLEASE WHEN STATING HP FIGURE QUOTE WHAT ROLLERS THEY WERE FROM AS THE DYNO JETS SEEM TO ADD A 100 HP TO EVERYTHING WE SEE HERE IN THE UK !!!!
also my numbers are done with pump fuel !!! no race gas also the engine and turbo are run everyday and provide a great everyday solution to driveabillty and response !!
EVO400turbos win races and lots of them . HP FOR BOYS TORQUE FOR MEN !!!!!
Old Jun 29, 2004 | 08:24 AM
  #471
EVO 400, is your turbo eligable for Grp N regs or not? just wondering.
Also, any news on your other turbo? dates when it may be finished. am i right in thinking you where looking at it making around 500bhp (on a rooling road in the uk on shell optimax LOL)?
thanks Chris.
PS shame you cant get your turbos over to these people. there is a lot of intrest in them! or if you can, any idea on a price for them? thanks
Old Jun 29, 2004 | 09:21 AM
  #472
bolsen's Avatar
Well a boost leak is goina be a problem man!
Just get some of the black rubber line (like fuel line or whatevers cheap) and some brass fittings. I used a plastic t fitting, but you may want to get another because mine always tend to break when I pull the line off it.
Old Jun 29, 2004 | 09:59 AM
  #473
Az3ar's Avatar
I am just worried. Do you think i got the light from the leak??? I mean its a small leak
Old Jun 29, 2004 | 10:02 AM
  #474
Zeus's Avatar
nm...
  #475
bolsen's Avatar
Well youre not going to know unless you hook it up and scan for codes. But my guess is that it is. I'd double check anyway just for saftey sake.
Old Jun 29, 2004 | 10:07 AM
  #476
Az3ar's Avatar
yea because the light did not show up until i started moving that Boost gauges
Old Jun 29, 2004 | 11:29 AM
  #477
EVOVII_SWE's Avatar
thanks Chris!
Their 3071 is NOT clipped, just got that confirmed with ATP
Old Jun 29, 2004 | 01:43 PM
  #478
Noize's Avatar
EvoM Administrator
I promise you once you are done with upgrading your stock turbo you are going to want something bigger. That's the way I went with my Jetta and I wish I would have just gone big to begin with because once you do, you lose all that money that you put into upgrading the little stuff (like reflashes, DVs, and that such.)
No offense, but if lag is not your cup of tea, a super charger would have been the answer to your problems. But obviously that's not applicable But what you also need to remember is just because the turbo doesn't spool as fast, that doesn't mean that you aren't makeing more/same power. I dont have the dyno's in front of me, but take a look at the POWER curve.
I don't know if this is been covered already but the OEM K03 turbo on the Jetta/GTi puts out the cfm of a fart compared to a big 16G. You HAVE to upgrade that tiny puke-n-die turbo immediately. The 16G has gone mid 11s with no nitrous in a car that is full weight. There's no single K03 in the universe that can do that in a full weight Dub.. Maybe if the 1.8T is modded and put in a Super7 LOL.
Old Jun 29, 2004 | 01:44 PM
  #479
Az3ar's Avatar
just to let you know K03 and K04 are great turbos
Old Jun 29, 2004 | 01:51 PM
  #480
Noize's Avatar
EvoM Administrator
For spoolup, but compared to a 16G? Get real, man. The 1.8T's limiting factor is that baby turbo. The guy comapred the stocker to an APR Stage III turbo, but the 16G is much more comparable to the APRIII unit than the crappy teensy K03.
