All Part Number Request Go Here
Old Mar 16, 2013 | 05:23 PM
  #3901
doncarbone's Avatar
Need part number of 04-06 Ralliart:
EDIT, I found it: Part number MD311571 (plate, cylinder block)
I need the transmission seal, or this little adapter strip which I'm guessing gives added reinforcement for mounting the starter motor. The one pictured below is a sample of what this should look like, although the one we have hanging off that bolt is for a different motor (OZ Rally).
Old Mar 18, 2013 | 07:52 PM
  #3902
420a-t's Avatar
I need one of these. Its the connector from the fuel pump to the housing. I pulled the wires out of the connector and need another one. Part number please
Old Mar 22, 2013 | 09:13 PM
  #3903
BkzProblem's Avatar
Ball joint boot
Im looking for a part # for the oem ball joint boot.. My Car came with whiteline ball joints and both of the boots ripped and i need to replace them A.S.A.P. I called up whiteline today and they just kept transfering my calls and i spent 1/2 hour on the phone with no progress.. So im just going order oem boots and call it a day.. Anyone With the part # please post.. itll be greatly appreciated..
Old Mar 22, 2013 | 11:04 PM
  #3904
nudge120's Avatar
mr455070
Old Mar 26, 2013 | 08:00 PM
  #3905
detroit pistins's Avatar
Looking for the 2 screws that hold the upper steering column in place, anyone aware of the part#?
Thanks in advance!
Old Mar 28, 2013 | 11:22 AM
  #3906
slimjim1804's Avatar
Looking for the bracket that holds the throttle cable on the front of the valve cover.
Old Apr 12, 2013 | 11:45 AM
  #3907
evo_skillz's Avatar
need part numbers for front-passenger side camber bolts.
Thanks you in advance
-Jonathan
Old Apr 12, 2013 | 06:01 PM
  #3908
Werdna06's Avatar
I'm having problems finding the right front ABS sensor part number 084-4069, if anyone knows where I could find one and in quick time that would be awesome.
Old Apr 13, 2013 | 08:54 AM
  #3909
sparky's Avatar
Does anyone know the P/N for a complete drivers side, non-HID, headlight sssembly for a 2003 EvoVIII?
Old Apr 14, 2013 | 02:42 AM
  #3910
todd6027's Avatar
MR569148 abs sensor rh front
Old Apr 14, 2013 | 02:45 AM
  #3911
todd6027's Avatar
-Jonathan
camber bolt MU000284
bottom bolt MU140067
single nut MD090875
Old Apr 14, 2013 | 02:47 AM
  #3912
todd6027's Avatar
fuel pump harness MR497597
Old Apr 16, 2013 | 10:14 AM
  #3913
Evo8lancer21's Avatar
oem rad support part number?
Old Apr 16, 2013 | 01:51 PM
  #3914
todd6027's Avatar
top rad bracket /rubber s , bottom mounting rubbers ??
Old Apr 21, 2013 | 02:01 PM
  #3915
stowasaurus's Avatar
could replace my camber bolt with any 14mm camber bolt since theyre the same size or are they unique to our cars?
