All Part Number Request Go Here
Old Mar 22, 2015 | 03:58 PM
  #4171
jason42003's Avatar
Front struts-MR554821
Rear struts-MN100475 w/o "special ride package"
MN101899 W/ srp
Old Mar 28, 2015 | 08:29 PM
  #4172
timmeqn's Avatar
part number for the clip that holds the heater control cable right before it attaches to the gears. green arrow pointing to the one clip I have
Attachment 240883
Old Mar 31, 2015 | 08:49 PM
  #4173
alexc's Avatar
I cant seem to find the part numbers for the two different size bolts next to the front tow hook up front.
The support beam( or whatever you want to call it) front bolts
Old Apr 13, 2015 | 03:57 PM
  #4174
BlackHawk_Tsi's Avatar
gsr 2008 sss
the drivers side under piece and the front spoiler lip.
Old Apr 14, 2015 | 05:08 PM
  #4175
stiffdogg06's Avatar
EDIT
After messing around forever today trying to find Part #'s for the items I needed; I stumbled upon this website. It is in Russian, so you'll need to translate it via google chrome translator or somehow.
http://mitsubishi-motors.kiev.ua/1/#
Find your body platform. For my 2006 EVO IX, it is CT9A. Click it, And then click on the link for your model EVO (GSR, MR, SE, etc). After that, you should be able to go from there.
Say you want an oil drain plug gasket, you go to the box that says ENGINE and click it. You then find what part of the engine you want. In this case, oil pan. You'll see a blown up diagram of the parts and they will be labeled with a 5 digit number. You click that, and it'll give you part #'s which you can cross reference with a OEM Mitsubishi parts website like www.oemmitsubishiparts.com for a price.
PM If you have any questions. Hope it helps!
Old Apr 16, 2015 | 02:00 AM
  #4176
jason42003's Avatar
Or you could just use mitsubishiparts.net which is same thing only already in English and based out of Washington so if you're like me and have no dealership in the state you can order from them. If you do have a local dealership just find the part, get part number and take it down to dealership.
Old Apr 16, 2015 | 03:31 AM
  #4177
That site sucks.
Click here for Engine, and then here for Camshafts, and then here Camshafts and timing, and then here for camshaft gear.
Plus oemmitsubishiparts.com is cheaper anyways
Old Jun 7, 2015 | 06:52 PM
  #4178
Jetech38's Avatar
I'm looking for the part number for a bolt that secures the passenger side motor mount to the engine. Bolt in question is the one with the arrow on it. 2003 Evo 8.
Any help is greatly appreciated.
Old Jun 7, 2015 | 10:57 PM
  #4179
doncarbone's Avatar
I believe you're looking for #MD194109
see diagram below
Old Jun 8, 2015 | 07:54 PM
  #4180
Jetech38's Avatar
You're a good man. Thank you.
Old Jun 23, 2015 | 07:16 AM
  #4181
thedru13's Avatar
So looking for all the part numbers for an Evo IX for the front and rear doors. the plastics so the for the window buttons but dont' need the buttons the inside of the door pulls but don't need the door handles and teh door pull in the arm rest. Also will need the little covers and the hardware so if anyone has those numbers would be really helpful. Hard to explain what those parts are for some reason ..
Old Jul 7, 2015 | 12:40 AM
  #4182
jmb_silvester's Avatar
have anyone know the part number of power steering return hose? below is the picture:
Old Jul 12, 2015 | 11:53 PM
  #4183
Phoenix*'s Avatar
Evo 8 Transmission Seal Part # needed...
Hi Gents,
Could someone please try help me find this seal part number for an Evo 8 transmission..?
Attachment 243618
Any help would be greatly appreciated.
Thanks.
Regards,
Marco
Old Jul 17, 2015 | 04:29 AM
  #4184
Hi Everyone,
does anyone know the oem partnumber of Rear Differential Mount Support
of evo 4/5/6
repplies are greatly appreciated
Old Jul 17, 2015 | 06:00 AM
  #4185
arkangel13's Avatar
Part # MB871240 HOSE, P/S OIL RETURN
Hope that helps!
