All Part Number Request Go Here
Old Dec 15, 2006 | 06:11 AM
  #1456
Spins4's Avatar
Originally Posted by Blue By You Evo
thanks for the numbers!
I am also looking for the part number and part actually of the JDM/UK Evo IX GT rear window. It doesnt have a hole for the wiper and doesnt include the rear defroster. Just straight glass. Could u possibly get it?
Sorry, nope :-( I tried with a few other JDM parts, but it just isn't happening yet.
Old Dec 17, 2006 | 09:09 PM
  #1457
geevolution's Avatar
part # for OEM brake pad shims
Old Dec 18, 2006 | 10:38 AM
  #1458
Spins4's Avatar
Front brakes:
Pads: MR407376 $199.94
Shim set: MR475618 $19.66
Clip set: MR475935 $39.50
Rear brakes:
Pads: MR407391 $199.94
Shim set: MR493188 $4.18
Clip set: MR475936 $6.82
All of which I have in stock.
Old Dec 18, 2006 | 04:06 PM
  #1459
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Part number for the two bolts that hold up the triangle shaped exhaust hanger.
Thanks!
Old Dec 18, 2006 | 08:10 PM
  #1460
Originally Posted by Spins4
Front brakes:
Rear brakes:
what are the clips?
Also would you mind providing me with the part numbers for all gaskets and washers necessary for a TME turbo, o2 housing, and exhaust manifold install? thank you
Old Dec 19, 2006 | 03:49 AM
  #1461
T88H's Avatar
Hi Guys!!! I need to know the part number of the EVO IX front nose mask.
Thanks in advance
Old Dec 19, 2006 | 06:11 AM
  #1462
Spins4's Avatar
Thanks!
MF243661
  #1463
Spins4's Avatar
what are the clips?
The part numbers that say "clip set" have the clips in them. As for your gasket list, are the TME ones and the oem ones the same?
Old Dec 19, 2006 | 06:12 AM
  #1464
Spins4's Avatar
Thanks in advance
Mitsu does not have one yet. Just checked on that yesterday actually.
Old Dec 19, 2006 | 07:07 AM
  #1465
But what are the clips, got a pic? The GT spec exhaust manifold and invidia o2 housing uses the OEM gaskets, and the TME too, also they reuse all OEM washers for all the lines. The problem is I don't have part numbers for everything
Old Dec 19, 2006 | 07:20 AM
  #1466
Spins4's Avatar
https://www.evolutionm.net/forums/at...1&d=1166127722
https://www.evolutionm.net/forums/at...2&d=1166127730
The clips are the 3rd box down, all the way to the right. As for the gaskets, you would need all the part numbers for a IX right?
Old Dec 19, 2006 | 08:14 AM
  #1467
T88H's Avatar
Ok thanks a lot for your reply!!! Also..they told you when release these part??
Thanks in advance,Javier
Old Dec 19, 2006 | 10:27 AM
  #1468
Spins4's Avatar
No prob, and unfortuantely, nothing as of yet.
Old Dec 19, 2006 | 10:46 AM
  #1469
T88H's Avatar
Do you know if there are a double din radio dash panel for the evo ix??
Old Dec 19, 2006 | 11:05 AM
  #1470
oh those spring things, I need all the part numbers for gaskets and washers for a 2004 VIII GSR
