View Poll Results: Warranty claim problems/ No claim problems.
Submitted claim, wasn't honored or had problems
129
58.90%
Submitted claim, no problems getting it fixed.
93
42.47%
Multiple Choice Poll. Voters: 219. You may not vote on this poll
Warranty Issues <Mega Merge>
Old Sep 15, 2004 | 03:06 PM
  #646
90GSX-03EVO's Avatar
Wow. How are you able to drive a car to the dealership with a thrown rod? Are you sure the rod has been broken? If so, I SERIOUSLY doubt that engine will run. Is the dealership even sure what is wrong with it? Are they just trying to get you to pay some ridiculously high labor/parts charge for an engine rebuild because they have no clue what is causing the oil consumption and the only way they can "fix" it is to tear the motor down and build it up again? To me, this sounds like the case. It also sounds like they are standing behind their "warranty denied" claim because they don't know exactly how to write it up and submit it to headqarters. I would start persuing this: "How the hell did my car throw a rod but it did not push that rod out of the side of the cylinder wall/through the oil pan and how is it I can still drive my car?"
  #647
ruthless evo 8's Avatar
When they pulled code on my evo and told me the issues i was dealing with, oil was not one of them. They pulled codes over my maf and o2 sensors but nothing involving cel over oil issues.
Old Sep 15, 2004 | 03:08 PM
  #648
silverofs's Avatar
this sitiuation sucks either way, you lost the oil out your motor! the dealer will tell you that higher boost pressure puts more load on the pistons probably causing detonation therefore ****ing your rings & cyl. walls up causing the failure. no oil means rod bearing takes a ****. good luck though if your boost was at stock levels you can win this battle in my opinion.
Old Sep 15, 2004 | 03:11 PM
  #649
90gsx - I asked a question almost like that and I was given the run around that my mods were the cause. I can tell they have no idea because I worked for a ford dealer for a year and when techs were giving different reasons for the same failure they didn't know sand from sky on what the hell happened. Next thing i'll hear is that all my mods worked together to over throw my engine.
maybe its an aftermarket conspiricy and they are working in conjunction with the automakers and the moon men too!
Old Sep 15, 2004 | 03:12 PM
  #650
that's why i had no fear of the BC because it is set to stock levels. it just gives me a more accurate reading down to .00 bar
Old Sep 15, 2004 | 03:14 PM
  #651
evo sky's Avatar
I totally agree with 90GSX-03EVO... I blew the motor in my '97 eclipse GS-T... rod actually made a hole on the block... oil leaked out... when i turn the key, u hear the cranking, but no way the engine will start... pretty sure its not a blown motor (or at least when u were taking it to mitsu)
but whatever they have done at the service department (maybe some amateur technician was revving it, what not), only they would know
can you tell us where the car is at right now (im assuming the dealership), did they try to start the engine, and the rest of the details?
side note: when my eclipse's motor blew, i left it at the dealership's lot (service department), waiting for them to estimate the cost of the repair... 2 weeks later they called me, telling me my car had been vandalized... my rims were stolen... my stereo was pulled... dont trust the dealership!!! (i highly suspect it was somebody from the dealership that did it)
  #652
Lowness's Avatar
u definately should of taken the boost controller off before going to the dealership.
Old Sep 15, 2004 | 03:17 PM
  #653
Nad1370's Avatar
You burnt up all your oil. probably doing it for a while, little by little getting worse. Causes:
worn or broken piston rings --- over boosting
oil rings broken or stuck in the groove allowing oil in the combustion chamber
Valve seals not sealing out oil---- over boosting
When you say No oil, do you mean no oil reading in the stick or no oil came out of the pan when they drained it?
Sorry about what happened but I don't think you have a chance on winning this claim with the mods they found in your car
Good Luck man....hope the dealer meets you at least half way on the expense.
Old Sep 15, 2004 | 03:18 PM
  #654
the car stalled twice on the way to mitsu and i was able to start it back up. The boost controller is a mute point because it was set to stock levels. Regardless if it was hooked up or not they would be blaiming my exhaust.
If anyone has any ideas on how the car could burn that much oil and still function properly it would really help because when i talk to them again i'll have some ammunition.
Old Sep 15, 2004 | 03:21 PM
  #655
there was no oil on the dipstick so i can only figure that i have very little to no oil left in the engine. To consume that much oil in 3 weeks though wouldn't I be leaving a smoke screen behind me when i drove down the street.
Old Sep 15, 2004 | 03:23 PM
  #656
i don't understand how people could be running 22psi on stock internals and not be running into this as an issue. I've only heard of one other case and he got screwed too.
Old Sep 15, 2004 | 03:28 PM
  #657
Nad1370's Avatar
Yes you would. It'd be like following a Dodge Caravan. he he he
Most of your oil is being burnt up in the combustion chamber. since your running catless, there is no oil build up in the converter for it to smoke up enough for you to notice.
I know 3 weeks is a short time to consume that much oil. But how many miles did you drive within those 3 weeks?
  #658
evo sky's Avatar
hmm this might be a lil off topic but.. where did you take the car to get the last oil change done?
And if they blame your exhaust rather than your manual boost controller for "the blown bottom end", you have a strong case, my friend
Old Sep 15, 2004 | 03:30 PM
  #659
EVOKing8's Avatar
PM ME I got some info for u
Old Sep 15, 2004 | 03:34 PM
  #660
Rez90's Avatar
sucks dude...good luck with that
