egt probe placement
Old Dec 21, 2006 | 02:46 PM
Danny23's Avatar
egt probe placement
Where is the best place for the most accurate readings to put an egt probe in. I,m putting back in my triple a pillar gauge pod with the autometer oil pressure, water temp, and egt from my 03 8 in my BR350 IX? I,ve heard the best place is in the #2 runner of the ex manifold. The only thing i am worried about is getting metal shavings going thru the turbo if i do it while its on the car.
Old Dec 21, 2006 | 02:49 PM
AngryJonnie's Avatar
http://www.zeitronix.com/installatio...stallation.htm
this is how zeitronix say you should do it.
geevolution's Avatar
if you're worried about shavings going through the turbo, then the safest way is to take the manifold out of the car
Old Dec 21, 2006 | 03:17 PM
Danny23's Avatar
thanks for the link Jonnie.
Old Dec 21, 2006 | 03:55 PM
althemean's Avatar
I wouldnt even bother. Get a wideband O2 instead. Then install the EGT. At least it will give you a reference of what the correct EGT's should look like. Other wise...all you have is a temp that is subject to placement of the probe.
Old Dec 21, 2006 | 04:04 PM
GPTourer's Avatar
You have to ask yourself, is it worth the risk? Is the gauge just to entertain you or are you seriously going to use it to tune your car to the razor's edge? Most likely it is the former. Put it in the O2 housing. You don't have to worry about shavings or a peice of the EGT probe melting/coming apart and damaging your turbo. And when you go to have it tuned, they'll probably have their own testing euipment designed to give more accurate readings anyway.
Old Dec 21, 2006 | 04:11 PM
BoostWhore's Avatar
u can do it on the car just drill where u have a ledge underneath for the shavings to drop. then use a magnet on a stick to grap all the big ones and then use a vacum to suck the rest out works like a charm
Old Dec 21, 2006 | 04:41 PM
revvin9k's Avatar
Old Dec 21, 2006 | 06:36 PM
sparky's Avatar
Where can I get the EGT probe with the S.S. braided protective shielding? My probe just bit the dust after 40K mi. on my diesel and then 15K mi. on the Evo.
Old Dec 21, 2006 | 06:41 PM
Jakeg97's Avatar
+1
its not that hard to take it off
Jovan Caro
Feb 22, 2017 11:04 AM
bboypuertoroc
Jan 9, 2009 02:47 PM
4cdndctn
Apr 20, 2008 02:53 PM
Racer24x
Lancer Engine Tech
Jul 26, 2007 03:08 PM
BADEVO
13
Dec 26, 2005 07:30 PM
