How much did you pay to save weight?
Old Feb 13, 2007 | 07:13 PM
  #61
9sec9's Avatar
If you know of a specific mini-battery AND tray (just part of it won't give the DIRECT replacement weight) let us know the brand and where to get it. I've also purchased the mini-battery for a vw in the past, but it wasn't in a kit. I had to create the tray, hold downs myself, so it wasn't really available to the general public. I'd like to keep the parts that are readily available to anyone.
Old Feb 13, 2007 | 07:37 PM
  #62
Autoxevo's Avatar
Buschur Racing mini battery and there aluminum bracket with hardware -- 15lbs, 5oz. Stock battery and hardware 35lbs.
Old Feb 13, 2007 | 09:26 PM
  #63
XK120's Avatar
great thread! you just need the carbon-kevlar roof from AMS...I believe that it's only 10lbs
Old Feb 14, 2007 | 10:05 AM
  #64
sonicnofadz's Avatar
Originally Posted by GreddyEvo
Nobody has a carbon fiber prop shaft to add to the mix! That is rotational savings you would be able to feel.
Carbon driveshafts are nice, but are a little pricey and tend to crack. They do indeed decrease weight (rotational weight) and also flex when under torque so they act as a kind of buffer (or torsional spring) so your drivetrain doesn't poop itself when you launch. I highly recommend aluminum driveshafts over carbon (for reliability and financial reasons).
Old Feb 14, 2007 | 10:52 AM
  #65
KevinD's Avatar
i've got another one to add to the list:
the ralliart twin plate clutch w/flywheel weighs 21.7lb
the carbonetics carbon twin plate w/flywheel weighs 21.8lb
the exedy twin w/flywheel weighs 28ish
the stock clutch w/flywheel weighs more then all of them. haha i'll get the weight tonight along with my coilovers.
the clutch mass may be sprung weight, but it is still rotational, and it rotates at your rpm speed, so upwards of 8k rpm. thats spinning REALLY fast. plus it has a relatively large intertia, so a reduction there is really felt. the clutch weight savings is going to be far more effective then axles or driveshafts because the driveshafts are rotating at the same rate as the wheels... which at 170mph is 2200ish RPM at 30 mph it is 400 wheel RPMs and 5200 clutch RPMs in 1st gear.
Old Feb 14, 2007 | 11:03 AM
  #66
Sharkbite2000's Avatar
I wonder how much does the tilton tripple carbon weighs
Old Feb 14, 2007 | 12:07 PM
  #67
dafunk630's Avatar
to much money to save weight for me
Old Feb 14, 2007 | 03:12 PM
  #68
9sec9's Avatar
Good comments sonicnofadz and KevinD, If you have advertised prices on these and stock weights, I'll post up the differences.
Old Feb 14, 2007 | 04:49 PM
  #69
dudical26's Avatar
My battery weighs 13 Lbs. That makes a savings of 22Lbs over stock. Cost was $34.65
That makes a $/Lbs ratio of - 1.575
Old Feb 14, 2007 | 05:54 PM
  #70
May I ask where you purchased a 13lb car battery for $34.65?
Old Feb 14, 2007 | 07:40 PM
  #71
dudical26's Avatar
Ask and you shall receive.
http://store.altenergystore.com/Batt...led-AGM/p1997/
And before you even ask, it works great. Started the car in -10 F Weather no problem.
Old Feb 14, 2007 | 07:47 PM
  #72
jordo's Avatar
how much does stock front impact bar weight?
Old Feb 14, 2007 | 07:50 PM
  #73
9sec9's Avatar
What kind of mods do you have. Wonder how it would perform under heavy load? Such as double fuel pumps, larger injectors, higher spark demands, etc? How long have you had it? What did you do for a tray? thanks
Old Feb 14, 2007 | 07:51 PM
  #74
dudical26's Avatar
13Lbs
Old Feb 14, 2007 | 08:01 PM
  #75
dudical26's Avatar
I have a single Walbro. Stock Ignition, Stock Injectors.
I have owned the battery for over a year but it has been in the evo for only 6-7 Months. Before that I used to use it to jump start my other cars
For the tray I cut a piece of aluminum and then I threaded the stock tie bars so that the threads go further down. Then I just put the aluminum over the battery and with the rods going through the aluminum and put two nuts to tighten it down. You can cut the battery tray and place the battery sideways to make more room if you want, I just did not care to. I left the battery tray stock.
This pic was taken for another reason but if you look you can see the top of the battery, the aluminum plate, and the tie downs.
