Modification Regrets?
Old May 30, 2012 | 08:30 AM
  #586
EnjoyDriving's Avatar
That sucks. Which shop did u go to, and did the shop refund or pick up the costs in fix-up??
Originally Posted by SmurfZilla
I regret trusting a shop to handle the build for my car since I didn't have the time, tools or technical knowledge to do it myself, which apparently they didn't either.
List of issues from the top:
1) Timing way off on the motor (Scott thankfully caught it before the more ate itself).
2) Wrong bolts used on crank pully and Fluidampr FELL OFF on the road. THankfully I was at a stoplight
3) Built Transfercase started deathwhine. Blamed on more power, more then likely improper fill
4) Head lifted......possibly due to not torquing down to spec (or not over torqued).
5) Triple Carbon clutch ate itself due improper assembly or improper install (Carbonetics words not mine)
6) New Quartermaster flywheel ate the starter while warping 200 miles into new install
7) Bell housing cracked from motor grenading originally and missed by said original shop so transmission was coming off block
8) Just found out from Shep that the following needs to be replaced: New Bell Housing, 1st gear, 2nd gear, 1st gearset, 1-2 hub and 3-4 hub, all syncros and sliders and input shaft. Basically an entire rebuild (Its a previously built Shep trans).
Thats all of the top of my head. I'm pretty much at the end of my rope with this car because of all the crap thats happened beyond my control.
All total because of one shops incompetence I have spent an extra 10k and I haven't driven the car for more then a few weeks with no issues. Hopefully this is it but if something major happens again there will be a fire sale and I will either rebuild and sell, throw a stock motor and setup in there and sell or part it completely out and wait until I can afford to buy a GTR.
Old May 30, 2012 | 08:36 AM
  #587
Well, i am agreed with you on that - for the IX, cams really don't do much becoz the stock cams are very good already. Luckily, my car doesn't suffer any of the rough ilding problems from aftermarket cams though
As for a tub manifold, I just put on the Mona Lisa (JessieB) and it made significant gain compared to my PPI ported/coated stock!! This was a real back-to-back experience becoz the mani was the only change, and I can feel the power all the time
Originally Posted by evo8426
Short of ported parts, a built motor, and a new turbo, I'd say my car is quite modified. I make right at 400/400 on e85
Old May 30, 2012 | 11:14 PM
  #588
casper980's Avatar
Originally Posted by IHEARTEVO8
Circuit hero shift extender! Cool at first but now I can't get it off my stock shift knob because it came with thread locker already applied and the long throw is unpleasant. Binary delrin shift knob is on the way.
A little heat should help that come off....
Old May 30, 2012 | 11:18 PM
  #589
Chaz17's Avatar
stickers. **** got old real quick
Old Jun 1, 2012 | 08:25 AM
  #590
irishcoffey's Avatar
Replacing clutch with stock one, doh!
Old Jun 2, 2012 | 01:19 AM
  #591
chaosfiend21's Avatar
act clutch....getting lockout after redline wth is 2nd and 4th gear? Speed density conversion...I dd my car and will stall from time to time with the ac on. Hks 272's should've gone bigger right away, barely any difference in power from stock cams.
Old Jun 2, 2012 | 09:10 PM
  #592
awdordie's Avatar
definately regret my forge motorsports piston type wga. i have had tension problems with the bracket sliding and losing tension even with the bolts tightened till the point where it feels like im about to strip the holes in the compressor housing. had an o ring break in half wedge itself between the piston and chamber and boost wouldnt go below 29 psi. after fixing that boost wouldnt go past 15psi no matter how much preload i put on it. i then bought a spring set and installed the 25# spring. with 3 full turns of preload from the 0 point i was only at 15psi... not 25 or anywhere close. with 6 full turns i got it to 19 and just used the ebc from there.
next time ill be going with a fp wga
Old Jun 16, 2012 | 11:24 PM
  #593
Brigganator's Avatar
nothing so far
Old Jul 1, 2012 | 07:08 PM
  #594
ccampbell's Avatar
Not going with a fp green or a bbk full instead of just a evo 9 turbo.
Old Jul 2, 2012 | 04:37 PM
  #595
lanevo005's Avatar
Mine would have been the K&N typhoon intake for the car. I hated the sound it made and how I needed a tune after installing it so I wouldn't over boost.
Old Jul 7, 2012 | 10:17 PM
  #596
PatricksEvilEvo's Avatar
me too a couple years ago.
Old Jul 10, 2012 | 05:18 PM
  #597
AJCaron12's Avatar
What does everyone dislike about the stock clutch if you're not racing the vehicle?
Old Jul 11, 2012 | 03:23 PM
  #598
wjamyers's Avatar
for my part it's the feeling that it will be ruined after one blown launch.
I basically don't dare slip/launch my car.
Old Jul 12, 2012 | 06:00 PM
  #599
Kidtkd73's Avatar
not getting a exhaust and only doing a downpipe
Old Jul 17, 2012 | 08:54 PM
  #600
makulitz's Avatar
Originally Posted by projectevo9
No regrets so far but I've just got my clutch done (ACT HD 6puck) and now it feels like I gotta let the clutch pedal up really slow at shifting otherwise I get this noticeable "boom"sound from my differential. My plan was to track my car once I put 500- 750 miles on this clutch. I gonna be afraid to do so.
i've been reading through 1st page up to here and just wondering do you guys know why is this "boom" sound is happening.. i do have an EVO IV with stage 2 clutch and this happens to me specially if i don't balance my gas and clutch very well..
