How To: Modding your Evo ~$100 at a time!
Old Sep 9, 2009 | 07:35 PM
  #226
Evo spec D's Avatar
Good thread,
just to add.....had the works short shifter, I was not happy with the action from 1st to 2nd grinding on occasion (took it out, back to stock) just left the previously installed brass under hood bushings with polyurethane shifter base bushings. The action remains very crisp throws a bit longer but much smoother.
one question......is there a pill or restrictor in the vacum lines on the stock IX BOV, or WG actuator?
I thought I heard of something like this somewhere.......thanks for the 411
Old Sep 9, 2009 | 09:41 PM
  #227
1SloEvoNoob's Avatar
awesome thread
Old Sep 10, 2009 | 08:37 AM
  #228
DevilDuck's Avatar
This needs to be stickied!
Old Sep 10, 2009 | 12:31 PM
  #229
Kracka's Avatar
Yes, one of the stock BCS lines has a restrictor in it. You can buy replacement pills or more simply just buy a MBC and be done with it since they're the cheapest, easiest, and most effective.
Old Sep 10, 2009 | 01:35 PM
  #230
falcontx's Avatar
Yeah.. why isn't this stickied?
Old Sep 10, 2009 | 01:38 PM
  #231
Kracka's Avatar
The mods think its too biased towards certain products/vendors/shops, but I only recommend what I've used and trust, simple as that.
Old Sep 10, 2009 | 01:59 PM
  #232
chaotichoax's Avatar
This thread is great info, but unfortunately as Kracka said he only is going off what he knows. It's not necessarily biased but it's his opinion and isn't fair to all vendors/parts alike.
Old Sep 21, 2009 | 04:16 PM
  #233
wjamyers's Avatar
This is one hell of thread.
I have to get a new clutch soon and I can't afford power mods right now so I'm just gonna do the stuff that centers around a clutch job (sorta):
I searched this site for hours (and the internet generally a little) researching every one of these decisions (except for BLOX and Crank Vents, pretty much took Kracka's word on them). As always I read conflicting info as to whether aluminum brass or poly bushings, how all of this will work together, whether clutch lines are worth a damn, etc, but I think this is probably going be a good set of mods.
MAPerformance says Fidanza has discontinued their shortshifter and I couldn't order it from them (I had already added it to my cart and was calling to confirm it had the base bushings).
So I tried to get it from VR Speed Factory
I was able to order it but who knows if it is actually available, I couldn't get anyone on the phone at 5:30 at night.
I know it's not $100 at a time but this is gonna be the first group of mods I do:
EVO Clutch Job+ Parts List
OEM Clutch - Ordered!
http://vr-speed.com/store/mitsubishi...on-p-1183.html
Fidanza Short Shifter Ordered!??? NEED TO CONFIRM!!! COMES WITH Base Bushings ??? NEED TO CONFIRM!!!
http://vr-speed.com/store/fidanza-sh...ion-p-763.html
Prosport Boost Gauge - Ordered!
http://vr-speed.com/store/prosport-c...ric-p-702.html
Works Poly Underhood Bushings - Ordered!
http://www.maperformance.com/works-s...g-kit-evo.html
Crankvents - Ordered!
http://www.maperformance.com/map-cra...acuum-kit.html
SS Clutch Line (Technafit) - Ordered!
http://www.maperformance.com/techna-...-line-evo.html
BLOX front motor mount - Ordered!
http://www.speedelement.com/index.ph...mart&Itemid=38
I also looked around for these
Upper pivot cup (part # MR246296 Retainer+gearshif) and #MR232147 (2) tiny cups for ball ends
and found them cheapest here:
http://oemmitsubishiparts.com/
The Crank Vent is not really related to shifting/clutch like all the rest but I was ordering from MAPerformance Anyway and it was only $45 and there seems to be a consensus that it's a pretty good idea so.....
Eff it. There it is.
Old Sep 21, 2009 | 05:26 PM
  #234
Evo spec D's Avatar
ok HOW do the crank vents achieve all the things that they are advertised to do?
I like to know form and function of a part when I install on the car
Thanks for the info
Old Sep 21, 2009 | 07:21 PM
  #235
wjamyers's Avatar
They say they can get the Fidanza short shifter but that it doesn't come with the base bushings. Dang. Now I have to source the base bushings. I'm partial to Kart boy's rep and I think I want to stick with poly. But the Energy Suspension are only $19.00 at VR:
http://vr-speed.com/store/engery-shi...on-p-1756.html
I already searched EvoM but didn't find much info on Energys.
Anyone have an opinion?
Old Sep 21, 2009 | 08:12 PM
  #236
Inprogress's Avatar
Is there any thread with the MAP Crankcase Vacuum Kit installed? I just wanted to see what the kit looks like put together and on an Evo. This thread is solid
Old Sep 23, 2009 | 11:12 AM
  #237
wjamyers's Avatar
Damnitt. VR can't get it either. Now I've gotta redo my Short Shifter search. Leaning toward Kartboy if it comes with the base bushings which I still need.
Old Sep 23, 2009 | 02:23 PM
  #238
Kracka's Avatar
Here is the shifter you want: http://cgi.ebay.com/ebaymotors/01-02...Q5fCarQ5fParts
Exact same as the Fidanza, B&M, etc. but at a fraction of the price. It includes the shifter base bushings too.
Old Sep 23, 2009 | 03:33 PM
  #239
wjamyers's Avatar
you're the effin MAN. done and done.
THANK YOU!!
Old Sep 23, 2009 | 06:47 PM
  #240
Evo spec D's Avatar
Thanks for the info
Kracka can you answer my question as well please
