New Full Blown 70mm cast TB
Old Nov 12, 2013 | 06:14 PM
  #241
blackgsx01's Avatar
Originally Posted by wjamyers
Are anyone else's throttle bodies cracking like this? Answer the question... yes or no?
this guy tightened it to much, same thing happened, so yes it has happened
https://www.evolutionm.net/forums/ev...le-body-2.html
Old Nov 12, 2013 | 06:20 PM
  #242
blackgsx01's Avatar
Originally Posted by PureDrivePerformance
Just to clarify, the OP didn't overtighten the TB as he sold me his BNIB.
I posted on post 177 that I cracked it. I reread what I posted and it reads like I tightened it snug then did 2 to 3 more full revolutions of tightening it down. That's not what I did. I may have tightened it 3/4 of a turn in 1/4 turn increments after I snugged it down.
It cracked right at the casting mark. I showed it to FB and they offered me a discounted BNIB, but weren't interested in an exchange. Fair enough. I decided that I will weld on a 3" ID aluminum tube with a thicker wall with a lip.
I agree on TB and all IC piping is to use hairspray on the pipe to coupler contact like you recommend.
I've tightened my stock TB much tighter than I did this TB, but I learned a lesson. As detroit pistins pointed out it may have been too small a T-Bolt. IDK as I've never had this problem before with any T-Bolt.
Yes the ultimate setup would be running something like a wiggins clamp just from the TB and UICP or http://vibrantperformance.com/catalo...1022_1250_1306
and there wouldn't be a issue
Old Nov 12, 2013 | 06:36 PM
  #243
PureDrivePerformance's Avatar
That's my video.
I looked into the Wiggins. It does have some $ex appeal Although for the price, one could buy another TB.
Old Nov 13, 2013 | 07:01 AM
  #244
wjamyers's Avatar
I guess you're misunderstanding my question. Yes, we all know that other peoples Full Blown 70mm Throttle bodies have cracked, as 10isace's did.
here's his vid:
While poorly worded the question I was asking you was ...
are any other manufacturer's throttle bodies cracking, yes or no?
Old Nov 13, 2013 | 09:42 AM
  #245
211Ratsbud's Avatar
I've had t bolt on mine for a while and just a couple days ago I popped mine off and replaced it with a constant torque clamp.
Better safe !
Old Nov 13, 2013 | 05:59 PM
  #246
wjamyers's Avatar
Nevermind.
Old Nov 13, 2013 | 06:03 PM
  #247
211Ratsbud's Avatar
I don't mind really swapping a clamp was like 10 mins. I'd still run the t bolt if I didn't drop the nut lol
Old Nov 13, 2013 | 08:06 PM
  #248
211Ratsbud's Avatar
And my idle has no problems ..
Old Nov 21, 2013 | 10:21 PM
  #249
Howulikemyevo's Avatar
Need help!!!!
Just finish install my FB 70mm tb on my evo 8.
Got it tune yesterday and the car wont idle properly. Keep on jumping up and down from 1800rpm to 1100rpm. I couldnt let it stay under 1000rpm because it will die out. Any on one dyno run, the tb got stuck on 4000rpm.
I read another thread on here and several people have the same problems. I bought this brand new from another evom member. So i know there is brand new without any scratches.
Faulty built?????
Thats whati been hearing from people.
Fix it or refund and i sent back the whole unit?!?!?!?!
Old Nov 22, 2013 | 08:28 AM
  #250
detroit pistins's Avatar
Originally Posted by Howulikemyevo
Need help!!!!
Faulty built?????
Your best option is to call them directly and ask them!
Full Blown Motorsports
3370 Mike Collins Dr.
Eagan, MN 55121
Phone: (952) 431-1399
Fax: (952) 431-1409
Old Nov 22, 2013 | 07:29 PM
  #251
Cool
Eagan, MN 55121
Fax: (952) 431-1409
Thanks bro.
But im try to see if i can get info from a actual person that have the same problems first , then call them later
Old Dec 18, 2013 | 06:31 PM
  #252
wjamyers's Avatar
This is my Full Blown 70mm throttle body crushed when I used an oversized (3", 79mm/87mm) t-bolt clamp.
http://www.flickr.com/photos/9969131@N03/11443715814/http://www.flickr.com/photos/9969131@N03/11443715814/ by http://www.flickr.com/people/9969131@N03/, on Flickr
http://www.flickr.com/photos/9969131@N03/11443669635/http://www.flickr.com/photos/9969131@N03/11443669635/ by http://www.flickr.com/people/9969131@N03/, on Flickr
http://www.flickr.com/photos/9969131@N03/11443846193/http://www.flickr.com/photos/9969131@N03/11443846193/ by http://www.flickr.com/people/9969131@N03/, on Flickr
http://www.flickr.com/photos/9969131@N03/11443847973/http://www.flickr.com/photos/9969131@N03/11443847973/ by http://www.flickr.com/people/9969131@N03/, on Flickr
Don't be an idiot like me. Check your sizes.
Old Dec 18, 2013 | 08:54 PM
  #253
wjamyers's Avatar
Old Dec 19, 2013 | 02:35 AM
  #254
Dragracer187's Avatar
I guess you use t-bolt clamps? Don't use t-bolt clamps, you now know why, T-bolt clamps sucks.
Old Dec 19, 2013 | 05:50 AM
  #255
wjamyers's Avatar
T-bolt clamps "suck"? No. But they do require precise sizing.
