New Full Blown 70mm cast TB
Old Jun 14, 2011 | 03:55 PM
  #46
Guerillah's Avatar
Got mine today, impressive piece for the price. Its closer to 72mm than it is 70mm. It also requires a 3" to 2.5" coupler to mate up with stock sized intercooler pipes (most kits out there). I will have a before and after dyno with the addition of a MAP Rev2 intake manifold as soon as they are done.
Old Jun 14, 2011 | 04:16 PM
  #47
wizzo 8's Avatar
72mm at the inlet but at the plate its 70mm. Curious to see your results.
Old Jun 14, 2011 | 04:33 PM
  #48
Guerillah's Avatar
Correct, after I took the picture I was feeling the inside of the the throttle body and noticed a very gradual taper to the inside. Once MAP gets my intake manifold done i'll post the results here although it will be with the addition of the manifold + throttle body.
Old Jun 15, 2011 | 10:29 PM
  #49
Erik@MIL.SPEC's Avatar
Originally Posted by 4xforce
Doesn't look like there is quite enough to port the manifold to a true 70mm. I'm gonna have to just try to smooth the transition as best I can. I think I'm gonna do that after testing it with just the adapter. I would be curious to see what the gains would be for both situations.
Yes, you would need to add material to the OEM manifold to properly use any TB over ~67mm. It looks like a very nice piece, but this is something to consider if you're using an OEM manifold. If you're using an aftermarket piece, this should not be a concern at all
Old Jun 23, 2011 | 08:34 AM
  #50
daishi77's Avatar
Can't wait to see results with this TB since this wwould be one of the last engine mods i would need for the most part.
Old Jun 24, 2011 | 05:23 PM
  #51
Guerillah's Avatar
Got my manifold back from MAP, they did an awesome job and did pretty well at welding the cast aluminum. I will be powdercoating the intake manifold to hide the scars. Dyno results in a week in a half hopefully!
Old Jun 24, 2011 | 05:31 PM
  #52
wizzo 8's Avatar
Any pics of the inlet of the intake manifold?
Old Jun 24, 2011 | 05:41 PM
  #53
Guerillah's Avatar
Took these for you, sorry they are phone pics. The throttle body isn't fully bolted down so its not lined up perfectly for the pics.
Old Jun 24, 2011 | 06:16 PM
  #54
wizzo 8's Avatar
Wow surprisingly good match
Old Jun 24, 2011 | 08:59 PM
  #55
javicracer's Avatar
im deff getting this tb with a map rev 3!!!!
Old Jun 24, 2011 | 09:31 PM
  #56
06MREvo's Avatar
Looking forward to more results...
Old Jun 25, 2011 | 08:52 PM
  #57
Guerillah's Avatar
Meh, figured satin black 900 degree caliper paint will work.
Old Jul 10, 2011 | 04:12 PM
  #58
anthonyrb98's Avatar
any updates with this tb? gains to be reported?
Old Jul 10, 2011 | 04:18 PM
  #59
Guerillah's Avatar
I just got my car running yesterday but now I am having misfire issues at peak torque. The car idles an drives beautifully with this throttle body. My plugs should be in Wednesday, if misfire issue is fixed dyno around then too.
Old Jul 11, 2011 | 07:13 AM
  #60
maperformance's Avatar
Would you think any less from us We are the porting kings sir.
