Intermittent Starting Problems - Mysterious Cause Identified and Fixed
Old Sep 15, 2016 | 11:28 PM
  #226
Sascha's Avatar
Originally Posted by Sascha
Very interesting, sounds like my problem.
Sometimes the Evo starts at first try. Then it takes 2-20 tries and all i hear is a click from the engine bay but no crank. Then suddenly it works like nothing happened
I´ll try it! Thank you!
So, i removed the plastic around the steering and i sa that the switch moves slightly and i saw the spark in the switch beneath.
Now i just have to get a screwdriver who will fit in, cause the dash is in the way, so another trip to home depot for a screwdriver who bends
Old Sep 16, 2016 | 06:35 AM
  #227
rhd-jon's Avatar
^ get a lil screw driver should work fine.
Old Sep 16, 2016 | 01:58 PM
  #228
Thoe99's Avatar
This is what I ended up getting. It worked perfectly:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old Sep 17, 2016 | 05:42 AM
  #229
rhd-jon's Avatar
Originally Posted by McLaren F1 2003
So to splice in the new HD relay, I'd cut both wires and solder both wires to their respective ends on the new relay?
So both wires on the pin #5 side (to the left in my pic) to wire 85 on the new relay? And both wires on the other side (to the right in my pic) to wire 87 on the new relay?
[/QUOTE]
Had this same dilemma with the two wires. I actually tied the wires wrong so i had to re do everything again because the car would not start. So after looking at what was posted above i then did the same. But when i did that i crossed the wires so when i started the car i heard a noise coming from the starter lower area so I quickly took the terminals off the battery. So i then changed the wires around and the car started up on the dime. I have to go back to the garage to finish up the job. Will keep everyone posted.
Old Sep 17, 2016 | 07:06 AM
  #230
rhd-jon's Avatar
So i went back to the car to try and figure this out but im having a lil issue
Car turns on fine with relay on right but im getting this noise.
So i took the connections from the relay off and started the car without it and i get no noise no nothing.
It's Like once i shut the car off the battery is still giving the starter power.
Relay i bought
Old Sep 17, 2016 | 09:09 AM
  #231
rhd-jon's Avatar
I mistakenly wired it up directly to the battery i need to find another source to wire it too
Old Sep 17, 2016 | 02:17 PM
  #232
rhd-jon's Avatar
Tried using the Cigarette lighter as another source but no luck seems like that's not a good spot
Old Sep 17, 2016 | 06:39 PM
  #233
rhd-jon's Avatar
So after all the back and forth i fcked up and wired it all wrong. Tomorrow ill fix the issue and keep everyone posted
Old Sep 18, 2016 | 01:34 PM
  #234
rhd-jon's Avatar
Unfortunately I could not continue with this set up. For some reason after fixing the issue the right way i seem to be getting power to the starter as soon as i pull the 30 to bat+ it then stops.
Old Sep 18, 2016 | 01:42 PM
  #235
Ted B's Avatar
That cannot happen unless something elsewhere is screwed up such that pin 85 has power full time (should have power only when starting), or the relay is wired incorrectly. So long as the starter circuit functions and the relay is wired correctly, what you describe cannot happen.
What I suggest you do is disconnect pins 85 and 86. Keep 87 wired to the starter, and then connect 30 to the BAT +. You should not hear the starter engage. If you do, either you (a) have a bad relay, or (b) are confusing pin 87a with 87. There are only finite possibilities.
If you do this and the starter does not engage as expected, then you check what you wired to 85. That should only be energized when the starter is engaged by turning the key with clutch depressed, and should not get power at any other time.
Old Sep 18, 2016 | 04:37 PM
  #236
rhd-jon's Avatar
Ok ill do that.
Old Oct 4, 2016 | 12:56 PM
  #237
JohnnyTSi's Avatar
Update on my fix - It's been a month now since I replaced the Key switch and starter relay:
https://www.evolutionm.net/forums/ev...l#post11660407
My car has started reliably ever since - WELL Worth the $50 Amazon purchases.
John-
Old Oct 18, 2016 | 11:01 AM
  #238
chdvg's Avatar
So I posted this thread yesterday: https://www.evolutionm.net/forums/sh...errerid=222804
but after doing a search, I may be having the same problem, I wouldn't classify it as intermittent since we have never been able to get it to start..but haven't tried 30 times in a row to start it. I can't get it to turn over by putting the ignition switch in my hand though.
Old Aug 3, 2017 | 10:41 PM
  #239
domestekoncept's Avatar
Having the same problem. Quick question. how and where is the starter grounded?
Old Aug 4, 2017 | 12:43 PM
  #240
Ted B's Avatar
The factory starter solenoid is grounded to the starter with a strap at one of its two large terminals (the other is B+), and the starter case is grounded via contact with the engine/transmission.
