New headlights on the block
Old Nov 26, 2010 | 09:40 PM
  #61
06MREvo's Avatar
I really like when the inside housing is painted black...looks great...all these headlights look awesome...
I really want to black mine out and do a fog light delete and put some air ducts in...
Old Apr 17, 2011 | 11:44 AM
  #62
iEvoVII's Avatar
The first Quad Projector set I'm doing besides my own.
45% done....
These are VIIGTA headlights for an VIIIMR onwner.
Headlight specs:
* OEM Single Xenon projector replaced with an FX-R BiXenon projector (Low & High beam)
* OEM chrome shroud dremelled away to fit an E46-R shroud in the low beam housing
* Front half of OEM projector retrofitted in the high beam housing for the "Quad Projector" look only (non functional)
* High beam housing dremelled to fit an E46-R shroud
* Custom aluminium shields painted red and installed to make all projectors look red
Owner will be installing an aftermarket:
* 50w rated D2S bulb (4300K)
* 50w Ballast &
* BiXenon wiring harness
Old Apr 17, 2011 | 02:41 PM
  #63
vtec lolz's Avatar
So sick, I want to send you my headlights!!
Old Apr 17, 2011 | 03:31 PM
  #64
donmeca2020's Avatar
looks good, i give you mad props for having the guts to open up your lights spray em down. i tried that once with my rsx and the lights came out like ****... lol YOU DA MAN!!!!
Old Apr 17, 2011 | 04:19 PM
  #65
Evolutionary8's Avatar
HOW DID YOU CHANGE THE OVERLAYYYYY!!!!! sick nasty
Old Apr 17, 2011 | 04:30 PM
  #66
wizzo 8's Avatar
Where do you get the clear lens for the turn signal?
Old Apr 18, 2011 | 02:31 AM
  #67
iEvoVII's Avatar
By "Overlay" you mean the housing that's now painted black???
Like I said before, I had to dremel the low and high beam housings to fit E46-R shrouds... Google "E46-R shrouds" if you don't know what they look like..
The ONLY CT9A headlight ever made that had the clear turn signal internally was for the 2002 JDM VII GTA (Automatic).... Google it
Old Apr 18, 2011 | 02:51 AM
  #68
MSD EvoVlll113's Avatar
looks nice
Old Apr 18, 2011 | 01:00 PM
  #69
iEvoVII's Avatar
nearly done...
Still waiting for owners 50w HID kit to arrive so I can drill a hole at the back of the low beam waterproof cover to feed the new low beam wiring + test out the 50w output...
Old Apr 18, 2011 | 04:42 PM
  #70
RunThat's Avatar
Nice work!
Old Apr 18, 2011 | 06:13 PM
  #71
Lazyfong's Avatar
How did you do "Light output modded for more BLUE at the edge"?
I haven't seen you post any info on this yet. Thanks!
Old Apr 19, 2011 | 12:42 PM
  #72
iEvoVII's Avatar
^^ google "projector washer mod"
Old Apr 19, 2011 | 01:50 PM
  #73
SRToad4's Avatar
Wow, that looks great...saw the same thing on a evox headlight project.
Old Apr 19, 2011 | 02:49 PM
  #74
forcefedr's Avatar
looks official on the yellow car
Old Apr 19, 2011 | 03:07 PM
  #75
iEvoVII's Avatar
A good chance it's a set that I modded... White Demon perhaps??
