Factory reflashes, hesitation, stalling, and everything you need to know [merge]
Old Apr 14, 2008 | 09:34 AM
  #226
GGEVO253's Avatar
Has anyone with mods done this reflash? I have the cone filter mod and AEM boost controller in mine. Anyone in WA get this reflash yet?
Old Apr 14, 2008 | 09:48 AM
  #227
Fiend's Avatar
Originally Posted by STi2EvoX
Oh and to DRAG, the comment about the car probably just making more power that day and that all cars can fluctuate from day to day based on the ambient temperature, I think you are a bit off base on this. All cars will fluctuate a bit based on temp, but not THAT much. You would have to do the first run in 120 degree weather and then go back when it's 20 degrees to see a gain like that. Usually, the most that a car will fluctuate with ambient temp (as long as the temps are somewhat similar and not extreme opposites) is 7-10 at the most.
The OP's first dyno session could have been affected by a bad tank of gas, it could have been extremely humid that day, who knows. The OP's engine is also wearing in so that could account for a slight increase in power too. Hell, it only gained 14whp, which is certainly not that much and if you take in your potential 7-10whp variance for temperature, that leaves 4whp, which is a perfectly acceptable variance from run to run...especially runs done months apart.
I would want to see more before/after dynos of this reflash before I started to jump up and down.
Old Apr 14, 2008 | 10:39 AM
  #228
junction's Avatar
Just got the X back after reflash.
Car runs obviously better
Idle at 750rpm
Holds boost to rev limit vs dropping out after 5500 rpm
Definite improvment.
No sputtering/hesitation so far.
Old Apr 14, 2008 | 10:40 AM
  #229
junction's Avatar
Idle at 750rpm
Old Apr 14, 2008 | 11:46 AM
  #230
92gsxbaltimore's Avatar
53 mph....PFFT, weaksauce
Old Apr 14, 2008 | 11:54 AM
  #231
StevenStarke's Avatar
i have a cone filter and aem tru boost and i'm going to get it done in the morning. I'll post up how it goes
Old Apr 14, 2008 | 12:02 PM
  #232
Mojito's Avatar
So the cars with VINs above the cut off already have this firmware from the factory and don't have any of the problems reported by the other owners (unstable idling or high rpm hesitation)? Can anyone confirm?
Old Apr 14, 2008 | 01:42 PM
  #233
DRAG's Avatar
Those 2 dyno charts are from different days, probably different outside temps, and probably not identical heat in the engine. It is completely irrelevant...though I HOPE it is correct
Old Apr 14, 2008 | 01:44 PM
  #234
DRAG's Avatar
Dang everyone is getting their hesitation fixed but me I'm going to go beat on it a bit here and see what happens. I guess I'll be taking it back to the dealer again.
Old Apr 14, 2008 | 01:56 PM
  #235
GGEVO253's Avatar
Please do, I just don't want any s%$# from my service rep. Have appt on Friday to get this done. I also don't want to take things apart then put back together.
Thanks
Old Apr 14, 2008 | 02:08 PM
  #236
08LancerEVO's Avatar
Originally Posted by JapanEvo4
スープラツインターボ
^who ever gets it gets a cookie.
スープラツインターボ = Supra Twin Turbo
NOW WHERE'S MY COOKIE!?
here you go
Attached Thumbnails Factory reflashes, hesitation, stalling, and everything you need to know [merge]-best_cookie-20.jpg
Old Apr 14, 2008 | 03:20 PM
  #237
love9sick's Avatar
I went by the dealer and I am too still call them Wednesday or Thursday. They apprantly tried to flash an EVO X and they said they failed. They said an engineer is coming tomorrow. Will see, I hope I don't get stuck with just a rev fix like DRAG.
Idle at 750rpm
That all sounds promising and great. I hope I am on this boat by next week
Old Apr 14, 2008 | 03:24 PM
  #238
love9sick's Avatar
I didn't judge it by the power increase. I say there is definitely a power gain by looking at the different behavior of the power band. If you showed me those two dynos I would think they are two different cars, not temp simply affected. I couldn't care less about hte 15hp, I just want it to run properly like a turbo car should past 5k rpm.
Old Apr 14, 2008 | 03:38 PM
  #239
si_to_evo's Avatar
getting the reflash tomorrow
Old Apr 14, 2008 | 03:50 PM
  #240
jdmhamster's Avatar
yes, thanks for sharing! pls. update us when you refill.
