ECUFlash 1.40 is out!!!
Old Oct 26, 2008 | 09:37 PM
  #61
SiC's Avatar
SiC
One of the first things that the USDM owners might want to try is the JDM Mivec maps. Totally different, JDM is way more aggressive. The timing and fuel maps are different also, JDM has more advanced timing and leaner AFRs but this is probably due to the difference in fuel. I haven't seen the EDM version yet so I don't know what their stock maps look like.
See pics, top is JDM and bottom is USDM
Attached Thumbnails ECUFlash 1.40 is out!!!-intake-vvt.jpg   ECUFlash 1.40 is out!!!-exhaust-vvt.jpg
Old Oct 26, 2008 | 10:11 PM
  #62
PR_Mivec's Avatar
interesting
Old Oct 27, 2008 | 05:30 AM
  #63
Deepseadiver's Avatar
I just went to the Tactrix web site and was going to get the cable ordered. Now I am not sure what to get.
#1 OpenPort 2.0
#2 OpenPort 2.0 with Full Adapter Set
#3 Tactrix 3-Port Boost Control Solenoid
What is the full adapter set for?? It looks like it has a few extra connectors. What are they for?
Also do I need the Boost Control Solenoid? I thought the the EVO X ECU could handle the boost just fine. Am I wrong?
I was planning on getting the DashDaq-ZEITRONIX WB02 to moniter boost, AFR's, EGT.
Thanks for the help!
Old Oct 27, 2008 | 07:00 AM
  #64
SiC's Avatar
SiC
#1 OpenPort 2.0
If you are only going to be tuning EvoXs then just get #1. The adapters in #2 is for older Evos and Subarus. #3 is a boost controller but we don't need this.
I was thinking about the DashDaq too but the problem was it doesn't monitor/show knock. I'm still waiting for a logger that can monitor knock.
Old Oct 27, 2008 | 12:22 PM
  #65
Thanks for the info! So how far out is better logging software? They should be able to do something like get the CEL to flash for knock like they did on the VIII and IX.
Old Oct 27, 2008 | 01:19 PM
  #66
Rguy's Avatar
Ordered my cable in anticipation of the software release!
Old Oct 27, 2008 | 10:46 PM
  #67
Evo_Jay's Avatar
This is what most do on IX. The JDM RS MIVEC map is popular on the IX.
Old Oct 27, 2008 | 10:58 PM
  #68
RazorLab's Avatar
I saw about 300rpm gain in spool on the dyno using the JDM Evo 10 mivec maps.
Old Oct 28, 2008 | 12:58 AM
  #69
gunzo's Avatar
I saw another 300rpms gain when you add in exhaust retard over the same rpm ranges
2300rpms 1.35bar boost FTW !!!!
Old Oct 28, 2008 | 01:32 AM
  #70
Stormtrooper's Avatar
awesomeness
Old Oct 28, 2008 | 03:45 AM
  #71
SiC's Avatar
SiC
Need to find those other speed limiter addresses and the SST related maps.
Old Oct 28, 2008 | 04:10 AM
  #72
spooled_u's Avatar
Very exciting times for the Evo X now that tuning will be increasing exponentially. I look forward to seeing best practices threads and different techniques used by people to get the most power out of this new platform.
It'd also be nice to be able to reset the flash counter...
Old Oct 28, 2008 | 05:52 AM
  #73
burnings's Avatar
Can you attach a copy of your ecuflash installation program so that we can download???
Old Oct 28, 2008 | 06:34 AM
  #74
gsrboi80's Avatar
Grats to all this is just the begining of seeing real fast DD X's. Nothing like being able to log and make your own adjustments.
A++++ ECUFlash
Old Oct 28, 2008 | 06:55 AM
  #75
goofygrin's Avatar
Damn STU limits to boost <grumble grumble grumble>
2300rpm boost makes me a little woody...
