COBB AccessTUNER Pro for 2008 EVO X (merge)
Rob, what is Cobb’s definition of Stage 2? Is Stage 2 for exhaust, intake or a combination of both? (Think on your website it says for Suby’s it was exhaust only). And of course the next question is
what the ETA date is for AP Stage 2?
Thanks,
Rob
Hey Robb, what's the ETA on the fix for the boost being max out @ 18 on the AP. I want to start logging star to learn about how the car operates. So i can gear up once i get my AFR so maybe i tune it a bit. Thanks.
Also there's was a rumor of you guys maybe making and upgraded boost line with a less restrictive pill and a map coming with it? Real or HOAX?
As soon as think I know what my plans are something like this pops up. I planned to get a mail in flash, but this looks promising.
Choices choices.....guess I will research further
Thanks,
Rob
It's the same 3 bar map sensor that the JDM/UK evo 8/9 models had that a bunch of USDM owners are now using so I know once you get the software cap off it will log 30+ psi no problem.
Maybe razor can explain it better.
Thank you.
If you ever decide to tune or just have some issue and want to log what the engine is doing it is better to have full and correct numbers. You can't sit and write boost numbers at each rpm and drive now can you
Interesting, I have logged it maxing out at 255 kPa. Which is around 22 psi or so (after taking out atmospheric) at sea level.
Theoretically you should be able to read out 22.48psi (255KPa-155KPa) from the ECU, but there is a factory conversion limiting the range of values. Therefore, if our conversion is correct, 18.287psi is the max value that can be displayed due to the factory conversion.
Feel free to PM me.
Thanks,
Rob
