The 3xMAP/MAF tables
Old May 25, 2011 | 12:07 AM
  #76
RS200Z's Avatar
Michael / David, thanks!
Old Jul 17, 2011 | 06:28 PM
  #77
lanasa's Avatar
Any new updates on these? I am looking at tuninga 2.3ltr, stock turbo, with meth..
Old Jul 17, 2011 | 08:23 PM
  #78
tephra's Avatar
you should increase all 3 tables by (2.3/2.0) = 15%
Old Jul 17, 2011 | 08:29 PM
  #79
RazorLab's Avatar
I'd also recommend smoothing them out from their OEM settings.
Old Jul 19, 2011 | 09:24 AM
  #80
lanasa's Avatar
Some days I just want to Hug you!!
I will see what I can do, I should have the block back in a week or so. I will have to prep my map this week and post it this week.
Old Jul 19, 2011 | 09:56 AM
  #81
lanasa's Avatar
OK now I feel like a Dee Dee Dee, how do I capture the screen of my Map on ECU Flash? I am running Windows 7.. I tried the Ctrl + P but it wont work..
Old Jul 19, 2011 | 09:57 AM
  #82
murlo26's Avatar
there is a print screen button as well on the keyboard.
Then open up paint and paste in there.
Old Jul 19, 2011 | 10:20 AM
  #83
lanasa's Avatar
OK so I am guessing it should look like this...
The map on the left is increased 15% from the second one. Now I guess I just have to do the other 2 maps
Attached Thumbnails The 3xMAP/MAF tables-15-increase.jpg   The 3xMAP/MAF tables-orignal.jpg
Old Jul 19, 2011 | 10:24 AM
  #84
RazorLab's Avatar
I would also smooth it out more, and more importantly, get the correct scalings.
Code:
<scaling name="StockXMAP in psig" units="StockXMAP in psig" toexpr="((x/4)*0.19347)-14.5" frexpr="((x+14.5)/0.19347)*4" format="%.2f" min="-15" max="35" inc="0.05" storagetype="uint16" endian="big"/>
<scaling name="Loadify" units="%" toexpr="(x*10/512)*10/32" frexpr="(x*32/10)*512/10" format="%.1f" min="0" max="300" inc="1" storagetype="uint16" endian="big"/>
Old Jul 19, 2011 | 11:00 AM
  #85
lanasa's Avatar
So its ok to add that to the Tephramod v1? I am just asking because I dont want to mess any thing else up.
Old Jul 19, 2011 | 11:02 AM
  #86
murlo26's Avatar
lanasa you need to get pro tuned man, lol. Your build/tune has gone beyond being able to post stuff up to get all the answer and testing stuff out yourself.
I wouldn't risk it.
Just do an etune from Razorlab or AMS or something for 300 bucks or whatever it is. It'll be worth it
Old Jul 19, 2011 | 11:14 AM
  #87
RazorLab's Avatar
None of that stuff should be in your Tephramod XML.
House it in your ROM ID XML (or whatever that ROM ID inherents)
Old Jul 19, 2011 | 06:50 PM
  #88
lanasa's Avatar
I wouldn't risk it.
I already was pro tuned. I still have to drive my car 30 mins home from the shop once I get it in. On top of that once I get get the cash and put 1000. miles on the block I was planing on on taking it back to get tuned. But I still have to drive my car an hour on the high way to get there before I can do that. My tune doesn't It doesn't have to be perfect, just cause me not to blow up until the block is broke in and I get get it back to the shop.
Just do an etune from Razorlab or AMS or something for 300 bucks or whatever it is. It'll be worth it [/QUOTE]
Ok, will add.
Old Jul 19, 2011 | 07:38 PM
  #89
lanasa's Avatar
Ok so I added that and the chart still looks the same.
Code:
Old Jul 19, 2011 | 07:43 PM
  #90
RazorLab's Avatar
Now that the scalings are in your XML you need to make sure those tables use them. Either change it in the XML by hand or in Ecuflash via the drop downs.
If via the XML, should look like this:
<table name="MAP based Load Calc #1 - Hot/Interpolated" category="Fuel" address="YOUR ADDRESS" type="3D" level="2" swapxy="true" scaling="Loadify">
<table name="MAP" address="YOUR ADDRESS" type="X Axis" elements="19" scaling="StockXMAP in psig"/>
<table name="RPM" address="YOUR ADDRESS" type="Y Axis" elements="19" scaling="RPM"/>
</table>
