View Poll Results: EVO X Transmission Problem POLL
Notchy, grinding, or difficult to engage gears (all the time)
689
40.08%
Notchy, grinding, or difficult to engage gears (only when car is cold)
646
37.58%
Difficult to engage Reverse gear (cold or warm)
146
8.49%
No problems at all
238
13.85%
Voters: 1719. You may not vote on this poll
The official Evo X notchy/grinding transmission thread
Old Dec 16, 2014 | 08:23 AM
  #1111
level100's Avatar
What help me a lot was flush the brake fluid. After bleed out all the old fluid it was night and day. No grind or notch at WOT or even normal driving
Old Dec 16, 2014 | 10:02 AM
  #1112
JDEve's Avatar
I have 55,000 on my 08 Evo X and it's a little tricky sometimes when I first start it up on a cold day. However, after running it for about 5 minutes it warms right up and shifts pretty good.
Old Dec 18, 2014 | 11:45 AM
  #1113
LiquidGraphite's Avatar
Originally Posted by level100
Mine does the samething. You should take note the way you hold your knob wich position give you a better shift. I found that if i hold my knob side way let say from 1 to 3 oclock it would go in little notchy when cold but when it warm butter smooth. But if i hold it at top of the knob i would grind everytime cold or warm. And to me the hard i pull to 2nd and push to 3 the smoother it get. It like to shift hard for some reason.
***A side note*** if anyone here hear or feel like something pop when you shifting check the shifter cables. It happent to me when i shift i feel like something poping out took me some time to figure it out. So finally pull the panels out and drove from to work and finally found that the cable slid out and in off the bracket. A good way to test it while parking shift to each gear and push down on the black piece that slide on the base repeat each gear until you find. I just zip tie it down and niose went away and shift alot smoother.
Thank you so much for posting this. I bought a TWM short shifter and after install, I noticed the clicking/ popping sound when I shift. I'm guessing because more effort is needed when shifting caused the brackets to loosen. Solved it with your post! But I actually used super glue rather than a zip tie in my case.
Old Jan 1, 2015 | 04:48 PM
  #1114
LastX's Avatar
I am very surprised that Mits has not rectified this issue after so many years. I was hoping it was going to be a breakin thing but 3200 mi, and I am still having have grinding between 2nd and 3rd, but also have trouble getting it into first at red lights, and in reverse.
Guess I will have to go back through this thread and make a list of the best options. If I recall my reading before a new clutch and STS is in order?
Old Jan 2, 2015 | 02:29 PM
  #1115
4EverWiKiD's Avatar
Veteran: Air Force
I just bought my 2014 Evo X last week, and have noticed the "rough" shifting even when the car is relatively cool/warm (idling for about 3-4 minutes in 30-40° weather), prerty much like all the standard cars I've driven. Third seems to be a little resistant when the car is babied through the gears and the RPM's are not revved around 3,500-4,000. Double clutching seems to help the shifting smoother. Like Level100 said, she seems to like when you're aggressive with the shifting, but haven't tested it out enough to say for sure.
Old Jan 8, 2015 | 06:41 AM
  #1116
d3FT's Avatar
I had recently posted about my reverse gear grinding on a brand new car (<24hrs of purchase). I took it back to the dealership and their service shop put in an order for a new transmission same day. The service manager said he had to call the Mitsubishi tech line to see what they wanted to do about it, and they recommended a whole new transmission. I should have it within the next week or so. Maybe others can request a new transmission as well?
Old Jan 20, 2015 | 07:47 AM
  #1117
rcb213's Avatar
Hey you guys, any experience 2nd gear being the most notchy out all your gears after letting the car warm up?
Old Jan 21, 2015 | 10:33 AM
  #1118
08LancerGTS_62's Avatar
Yes, the issues I had were with 1st into 2nd, getting into reverse and going back into 1st. I have to fight/ play around with it for it to finally go. usually double clutching seemed to help but shouldn't need to do that. I want to try flushing the fluid like someone said in an earlier post.
Old Jan 21, 2015 | 10:49 AM
  #1119
rcb213's Avatar
I have had the car for 3 months, do you think it would be worth taking it into the dealer?
Old Jan 21, 2015 | 10:56 AM
  #1120
Legit.. me too... I got the car around mid OCT. It's still under warranty so wouldn't hurt, just might need to leave it for a day or 2 which stinks.. my car is in the shop now, but only because someone wanted to use my trunk to slow down... but I want to change the fluid 1st before I bring it in to see if that helps. but either way should be covered.
Old Jan 21, 2015 | 11:09 AM
  #1121
rcb213's Avatar
Thanks for the info I'll probably give them a call. My 2nd gear grinded the other day because it was giving me a hard time to get into second (with my foot planted into the clutch to get into that gear)
Old Jan 21, 2015 | 11:13 AM
  #1122
yeah im glad im not the only one in this situation. I feel almost like im doing something wrong when it doesnt work, but i mean what else can you do when you're already on the clutch lol. but I do see that double clutching it does work. so for now try that out to not grind, but let us know any outcomes. good luck mayte!
Old Jan 21, 2015 | 11:18 AM
  #1123
rcb213's Avatar
Thanks! I already made an appointment for the dealer just now. Will let you know what they say!
Old Jan 21, 2015 | 01:12 PM
  #1124
rcb213's Avatar
I took my car for a spin right now and this is what I got, only with 2nd gear.
WOT- 2nd notchy
Normal 3500 to 4k - very notchy
Parked and passive shifting, guiding the stick - a pause going in and I have to push it in.
From reading a couple of the threads its just a Mitsu thing?
Old Jan 23, 2015 | 11:55 AM
  #1125
rcb213's Avatar
So I went to the dealer today and they told me there was nothing they can really do because the car is in the break in period phase. The tech told me the break in period ends at about 15k to 20k ( Can anyone verify this)? He also told me that in the 13-14 the bushings connected to the transmission lines are soft and thats why its so damn notchy/clunky/ you name it. He advised me to go with some solid aftermarket bushings to get rid of the issue.
