View Poll Results: EVO X Transmission Problem POLL
Notchy, grinding, or difficult to engage gears (all the time)
689
40.08%
Notchy, grinding, or difficult to engage gears (only when car is cold)
646
37.58%
Difficult to engage Reverse gear (cold or warm)
146
8.49%
No problems at all
238
13.85%
Voters: 1719. You may not vote on this poll
The official Evo X notchy/grinding transmission thread
Old Aug 13, 2014 | 08:23 AM
  #1081
Turbotastic's Avatar
My 2013 has had the notchiness since I got it over a year back. I thought it was a normal Evo thing lol. But recently I test drove a 2014 for the hell of it and it was buttery smooth, even at cold start. I thought maybe they finally smoothed out the tranny but I guess not?
Old Aug 18, 2014 | 10:56 PM
  #1082
spdfour's Avatar
Test drove a new 2014 notchy as heck
Old Aug 18, 2014 | 11:31 PM
  #1083
Thom93's Avatar
I've changed the shifter (torque solutions), the base bushings, the underhood bushings (to the ones form AMS) and the transmission oil - now it's perfect. Before it was notchy7grinding all the time...
Old Aug 19, 2014 | 08:07 AM
  #1084
level100's Avatar
What kind of transmission fluid you.using? I got twm bushing kit. Torgue short shift. And amsoil synthetic synchromes and still grinding. Thanks
Old Aug 28, 2014 | 02:33 PM
  #1085
GSR G's Avatar
Mine fixed itself after a few hundred miles. Its been great for the last 9000 or so.
Old Aug 28, 2014 | 09:45 PM
  #1086
The bug's Avatar
Same issue here
I am also having problem with Evo x grind from 2 to third only. But from 4th to 3rd is fine. I'm worried it is doing damage to my tranny. Doesn't happen as often now that I have weighted shifter but happens daily none the less. Wish I knew how to vote on your poll. But mark me down for it happening all he time. Fix this **** Mitsu!
Old Aug 28, 2014 | 11:11 PM
  #1087
vitamin4b11t's Avatar
i have 14 GSR and when i first got it, the trans felt super notchy thought that i wasn't stepping on the clutch all the way down but soon figured that wasn't the case....... it would normally grind u could say when going from 1st to 2nd and 2nd to 3rd but I'm at like 3k miles on the car now and its been feeling a lot better hardly any notchyness and also noticed that once i drive for a good 5-10 minutes it mostly all goes away .... oh and before i bought my car i test drove a evo x and that thing too had a notchy trans.... guess its just a evo thing ?
Old Sep 15, 2014 | 09:51 AM
  #1088
02modlanceroz's Avatar
Mine was really notchy when I got it and still is if I'm not shifting right. If I'm driving around town and can only drive like my grandma, if I double clutch it, completely smooth shifting. I was only having the problem from 2nd to 3rd. The only way I notice it in other gears is if I'm late on the clutch pedal. If I got the car around 5k rpms and drive it like you should. Absolutely no problem, unless lazy with the clutch. So if I'm not getting on the car I double clutch and have no issues.
Old Sep 19, 2014 | 06:41 AM
  #1089
cleudson's Avatar
I have a 2011 evo X MR with 14k miles and my 4th gear disappeared yesterday, even in manual mode. After sometime, the message "transmission service required" appeared. Some minutes later and in automatic mode, the 4th gear came back and the message was gone. Today everything is still ok. What can it be?
Old Sep 24, 2014 | 12:07 PM
  #1090
05OBP's Avatar
Relieved to hear that this is common, my 2014 GSR is a couple weeks old with 430 miles on it and I get the 1st to 2nd and 2nd to third "notchiness" when shifting. It certainly is more noticeable when cold and does seem to remedy itself after the car heats up.
Old Sep 24, 2014 | 01:00 PM
  #1091
I installed the works short throw shifter and mount bushings today. What a difference. Car shift so much more precise. I'm right around 900 miles. I'll be install the cable bushings and pivot bushing this wkend
Old Sep 24, 2014 | 01:53 PM
  #1092
.M.'s Avatar
.M.
08 GSR. 47k. Only notchy from 2nd to 3rd while driving normally (doesn't bother me). No issues with spirited driving.
Old Oct 10, 2014 | 07:05 AM
  #1093
Mitsubishimark's Avatar
My GSR 2014
Originally Posted by gyroscope
took my evo x out of the garage and put a couple hundred miles on it today. Its a 2013 with 500 miles on it. Only problem is 2-3 shift when shifting quickly. It doesnt grind but it feels like a metal scrape. Been like this since i bought it new. Im the only driver and never misshifted/grinded it.
My Evo x is brand new and it kind of grinds into 3 rd gear which I am sure is normal as I am only used to my previous 2012 sti tranny which felt completely different .
Old Oct 10, 2014 | 07:13 AM
  #1094
My Evo x 2014 GSR
Same thing right off the lot good to hear its normal .
Old Oct 10, 2014 | 07:22 AM
  #1095
My new Evo x
Originally Posted by Joe's Evo X
Dont take this the wrong way but you said this was your first manual so it might be for inexperence of driving the car. Give it time and let you skill get better to see if it improves if not the it might just be the car. (i remember my frist time driving a manual )
Sounds just like mine and I have many years of experience driving stick ,so no worries .
