View Poll Results: EVO X Transmission Problem POLL
Notchy, grinding, or difficult to engage gears (all the time)
689
40.08%
Notchy, grinding, or difficult to engage gears (only when car is cold)
646
37.58%
Difficult to engage Reverse gear (cold or warm)
146
8.49%
No problems at all
238
13.85%
Voters: 1719. You may not vote on this poll
The official Evo X notchy/grinding transmission thread
Old May 4, 2013 | 06:13 PM
  #991
Gyroscope's Avatar
took my evo x out of the garage and put a couple hundred miles on it today. its a 2013 with 500 miles on it. only problem is 2-3 shift when shifting quickly. it doesnt grind but it feels like a metal scrape. been like this since i bought it new. im the only driver and never misshifted/grinded it.
Old May 7, 2013 | 01:08 PM
  #992
Smoothgangsta's Avatar
Old May 9, 2013 | 07:36 AM
  #993
I might just drive it another 10-15k miles to see if with time and wear the issue will be mitigated.
Old May 10, 2013 | 05:48 PM
  #994
Gyroscope's Avatar
same, it gets a little better when the tranny fluid is hot but still scrapes on quick shifts. still not bad enough for me to go through having the dealer drop the tranny and doing something incorrectly or ending up with leaks afterward or something.
Old Jun 4, 2013 | 07:13 AM
  #995
joey0480's Avatar
I have about 600 miles on mine. 1-2 is notchy......and 2-3 gets grindy....that is what worries me. It definitely is not as bad after I have been driving for a 1/2 hour or so when the weather is around 75 plus.
I am supposed to pick up my keys on Friday so I may ask the mitsu tech his throughts on it.
Old Jun 4, 2013 | 07:57 AM
  #996
xBoostx's Avatar
I have noticed that you can get a scrape sound/feel and certain points during a shift. For instance you can feel when its going to be a smooth shift or when its going to feel like a metal scratching feel before it goes into gear. If you shift very quickly (driving normal) you wont get it. if you shift medium speed (normal) you may get it especially 2 to 3. if you shift slow about a sec after you press the clutch you wont feel that grind type feel. Its all about how you shift.
you dont want to pull/push the shifter off to one side to much. you kinda want to just guide the gears in. This style helps tremendously. Of course im speaking of a stock shifter setup. Im seriously considering upgrading the whole system to the twm. Not because i dislike ours but because I drove a friends 2011 Stang GT with short shifter and oh my was that lovely. And lets not even get to a customers C5 with complete B&M setup. so crisp and short.
I probably will end up switching since it makes the car so much more fun to drive.
Old Jun 4, 2013 | 08:03 AM
  #997
xBoostx's Avatar
I have also heard of the reverse problem. I havent had it, but at times it does feel a little harder. What i have done that has pretty much eliminated that is shifting to 3rd then reverse.
Old Jun 16, 2013 | 03:11 PM
  #998
alvinevolutionX's Avatar
My car grinds into 5th gear when shifting normal but If I delay the shift and let my RPMs go below 3K to shift the gear wont grind. I bought the Krackas shifter package from MAP and used the Redline cocktail fluid that came with it and did the tranny fluid change at only 11K miles and the new fluid has settled in and my 5th gear still grinds :/.. Any recommendations before having my tranny rebuilt to fix my synchros?
I came across the forums and read about the pennzoil synchromesh. Has anyone used this before?
Old Jul 2, 2013 | 05:19 AM
  #999
joey0480's Avatar
My reverse has become a pain and i am only at 1K. I have to usually try and let the car roll a bit and then it goes in no prbs. But from a stand still I have to sometimes really put it in.
I have a notch to 2nd until it is really warmed up. I thought something was wrong with third till I read this thread. Third gear feels notchy/scraping getting into
Old Jul 14, 2013 | 05:12 PM
  #1000
timmy2754's Avatar
My 2012 has the same issue with 2nd and 3rd. I just changed the fluid with the redline cocktail. I noticed a difference right away. But when I drained the old fluid there was quite a bit of metal shavings on the magnet and I only have 11500 on the car.
Old Jul 24, 2013 | 11:26 AM
  #1001
jezthevalley's Avatar
Mine's at 50k kilometers and had the same problem. But once i've installed my short shifter setup + bushings, 95% of the problem went away.
My best guess is having a short shifter, just changes the way I shift. because like a lot of people have said, you need to shift a certain way in order not to feel that notchy/grind.
Old Aug 16, 2013 | 09:47 PM
  #1002
w1zofoz's Avatar
I've had my 2013 x for 13500 miles now and it still grinds from 1-2 and 2-3. I also sometimes can't shift into reverse without first going into another gear or letting off and pushing the clutch down again.
Old Aug 17, 2013 | 02:11 PM
  #1003
naveed80's Avatar
Mine gives that little grunt sometimes going into second and third. Overall its come a long way. First 2-3k miles were horrible, the 2nd grear would almost want to pop out while i'm trying to engage it. Man I havent changed my gearbox oil yet and I'm @ 25k miles now. Must do that and rear diff before summer really ends.
Old Sep 4, 2013 | 06:30 PM
  #1004
Evo_Vinh's Avatar
Hey guys my bud has an Evo 9 just replaced the tranny with a used one. All linkage is good fluids changed out twice and adjusted the clutch pedal as well as replace the shifter lever and slave master, bled the fluid and the gears 1-6 are very notchy. It is hard to put any gear in and you have to practically use force and fight it in. Any ideas?
Old Sep 6, 2013 | 10:42 AM
  #1005
fenixz's Avatar
Just reading through this. I had a 2011 WRX and no grinding/scraping with any gears. My bro has 2011 mustang gt 6 speed, no grinding/scraping. My 2014 evo x grinds towards the 3rd gear and reverse is a pia sometimes. I'm guessing nobody brought this to the dealer and to have checked??
