CBRD BB-X turbo update... and products again!
In all honesty the AMS dynojet seems to read the most truthful and inline of dynojets. God I hate dyno arguments. Why did I post this.
- Bryan
- Bryan
I'm going to try and get a boost plot for comparison sake posted today, holding 30+ psi sure would be nice.
The reason that most people are interested in this thread is because the BBK full is awesome on the 8/9. I wouldn't pre-order one, prior to seeing a single dyno graph, if I didn't expect great things. I personally don't care if it is 20hp + or -. It's about doing the best with what you have to work with, imo.
Sorry for not being in this thread over the holiday! I was moving! and couldnt get online!
More is coming, the GST car had some hiccups and is being corrected... this time of year makes it tough for anyone to get anything done...
there will be more coming shortly,
im getting a quite a few pre-orders... so once the wheels are blue we will let everyone know when we can ship
cheers
cb
cheers
cb
Is the "BB-X" a BBK version for the X or is it the bigger wheel "BBK-XL" version for the X? 57 lbs of flow sounds a lot higher than the BBK for the viii/ix at ~47 lbs of flow. How are the spool characteristics with the BB-X?
We were seeing 28psi on our car by 3900 rpm in 3rd gear with the following mods..
CBRD version 1 beta FMIC (vertical design, which I ditched.. because it showed no gains over our horizontal, and it cost too much hee he)
Stock IC pipes... AFE cold air intake
Stock O2 housing, Stock Downpipe
CBRD resonated test pipe and CBRD Catback
DW 800cc injectors...
CB
CB
CB
CB
but with the mods I had, it was too much boost for 93, and was knocking up top, so i tapered it.
we went from 312whp/322wtq at 26 psi on the stock turbo, to 372whp/338 wtq at 27 tapering to 24 on the BBX...
CB
using the same boost table that I used on the GT3076R.... It made 5.5 more psi on our car.... and spiked to 32psi.... so that was a good sign
and I think similar or almost right on top of what you see from GST motorsports!!
CB
with a 3 port prodrive solenoid I could hold it flat to redline no problem...
CB
CB
