CBRD BB-X turbo update... and products again!
So, yes, it's a true 30 psi all the way across at 4500 ft
this compressor kicks ***!
Yep, I try to zero it out every other time I data log. It's +/- 0.2 psi off at most. But it would be reading dangerously low if it were still calibrated for sea level... which would be bad.
this compressor kicks ***!No cat correct?
- Bryan
Red's make about 430-460 on our dyno @ 30psi on good fuel, Evo 9. On pump, 35Xwhp. Which is about what reds make on the 10 on our dyno, on pump.
- Bryan
I've started looking into double pumps for E85 and I'm not too happy about the options--everything affordable requires sending in your pump housing and being without a car until it is returned. Not attractive for those of us that only have one car.
Heh, last I checked the AMS DynoJet reads pretty average at around 20% losses plus or minus a few percent. I think GST's is closer to the heartbreaker side of the spectrum like Buschur's or STM's Mustang Dyno at 30% losses but not sure how close.
Comparing an Evo 9 on an FP Red on another Dyno with unknown Evo X baselines is going to be impossible to compare directly, way too many variables.
And there's usually no need...if you live in a decent size city then your tuner will have seen one of everything on the dyno that you use.
