HELP! I threw a CEL
Old Jan 30, 2010 | 11:08 AM
Evolutionary1's Avatar
Exclamation HELP! I threw a CEL
HELP!!! Just did a little snow drift and all of a sudden threw a CEL. Now the car when I start it idles at 2000rpm and gradually goes up to 2500rpm. I did a reset and still the same thing it won't come down from this high idle. My mods are Nisei upper and lower ICP's, HKS air filter, Greddy DP non open mouth, and HKS Hi-power exhaust. Any help would be greatly appreciated.
Old Jan 30, 2010 | 11:09 AM
GEOFF[4G63]'s Avatar
Check out everything under the hood? sensors still connected, vac hoses etc?
Old Jan 30, 2010 | 11:10 AM
FedEvo8's Avatar
Turn off the car and turn it back on. It will reset by itself.
Take it to someone who has an OBDII CAN reader.
Old Jan 30, 2010 | 11:11 AM
XdsEVO8X's Avatar
One of your vaccum lines could've popped off I would check those, also are you running a testpipe and no cel fix?
Old Jan 30, 2010 | 11:25 AM
hotdog's Avatar
How do you NOT have a like a 50 dollar OBD-II reader? Really? I mean, really really?
Old Jan 30, 2010 | 11:28 AM
I know I'm working on getting one right now. No I don't have a test pipe at all
Old Jan 30, 2010 | 11:46 AM
I have this line disconnected, but I can't remember if this is disconnected because of the Nisei intake tube?. Was awhile ago I did this mod. Any idea on this line?
Old Jan 30, 2010 | 12:03 PM
Clark_Kent's Avatar
Turning off the car doesn't reset a CEL. Get an OBD-II scanner and pull the code. How can we help you if we don't have the code? It could be anything.
Old Jan 30, 2010 | 12:18 PM
hotdog's Avatar
Have you gotten tuned yet? And if not... why not? I mean, besides the "safety" aspect of it, you'd get a gigantic boost in power with a tune. You're running a lot of fairly expensive mods.
Old Jan 30, 2010 | 12:30 PM
I disconnected the battery to reset the ECU for a half hour. I will try to get the code when I can borrow an OBD II reader from my father in an hour, just wanted to see if there was any others that have experienced this. As far as a tune goes I wanted to get another UICP, FMIC and a test pipe and then I was going to get a tune. I guess there is no short cuts, I just wanted to do the tune once and have it last awhile. I guess I will post back in a hour or two when I get the code. Thanks for the replies.
Old Jan 30, 2010 | 12:41 PM
El_Kameleon_G's Avatar
I think that should go back into the inlet pipe. Idk it's pretty close up. So yeah possible vacuum leak, but not enough to cause a 2000 idle.
Old Jan 30, 2010 | 09:39 PM
skyseer's Avatar
bad maf ?
Old Jan 31, 2010 | 09:14 AM
CanEvo09's Avatar
I see you are from Canada also. What was the outside temperature when you drift your car. The cold weather probably yield a couple more psi of boost versus your normal tune and in return your car might have exceed the torque table values.
That happened to me even on a near stock tune. Lately with the outside temp. being in the -15C/-20C depending where you are located your car might have overboosted.
slammedndirty
Sep 17, 2013 11:23 PM
barrman
Oct 23, 2012 05:48 PM
forum04pl
Aug 14, 2005 01:18 PM
rpm-evo
16
Dec 25, 2004 03:28 PM
digdat
Lancer Engine Tech
Apr 1, 2004 12:43 PM
