Sponsored by:
Sponsored by: CARiD
Defective Stock Recaro Seats
Old Mar 4, 2009 | 12:33 PM
  #196
Xtremist's Avatar
Dealership told me it typical of the vehicle, refused to do anything about it! Also said the transmission issue was due to it's high gear ratios and also went so far as to try and point the finger at me for my aero package rocker molding issue! Terrible paint quality, refusal to start at times and flimsy bumper moldings and weak front windshield's are just to name a few issues this car has!!!
Old Mar 4, 2009 | 12:34 PM
  #197
Xtremist's Avatar
Oh BTW "Welcome to the fold"!!!
Old Mar 4, 2009 | 12:52 PM
  #198
jmorris1027's Avatar
My dealer finally ordered me new seat backs after about 3 trips there bugging them. They said the new seat backs are updated with more cloth arount the plastic parts to avoid the problem.
Old Mar 4, 2009 | 12:56 PM
  #199
gotevo?'s Avatar
I'd give your local dealer a kick in the groin..... ouch.
On subject: both my seats are doing this. Will take it to the dealer soon for oil change and see what they say
Old Apr 20, 2009 | 10:53 AM
  #200
phillyexox's Avatar
so it seems like dealerships are fixing the problem by replacing the whole seat? I too am having the same problem.
Old Apr 20, 2009 | 11:09 AM
  #201
Xtremist's Avatar
Same issue, but my rep told me it was a characteristic of the seat it's self! Just like he told me the aero rocker molding issue was on my end!
Old Apr 20, 2009 | 01:30 PM
  #202
Clipse3GT's Avatar
What dealer do you go to in ohio?
Old Apr 20, 2009 | 01:43 PM
  #203
Noize's Avatar
EvoM Administrator
merge
Old Apr 20, 2009 | 02:24 PM
  #204
300zxsteve's Avatar
This is brutal. I hadnt looked at my seats to check if anything like this had happened. Is height or weight a factor?
Old Apr 22, 2009 | 11:58 AM
  #205
orlando628's Avatar
i had my x for 2 week and i have the same problem with the seat imma take it back to the dealer and also idle problem and the car is stock O_O with only 1k miles
Old May 3, 2009 | 08:32 AM
  #206
Farred's Avatar
im having this problem too. i will try to fix it myself but if it looks to bad i will just take it to the dealer.
Old May 3, 2009 | 10:47 AM
  #207
droppinbottom's Avatar
I just got my x last week and the passenger seat has this issue with it as well. I am going to take pictures of it and email directly to mitsu and most likely take it in to my local stealership and try to get them to document the issue. I am sitting currently at 1147 miles. A 800 mile trip home from the dealership adds up quickly.
Old May 3, 2009 | 11:28 AM
  #208
John83's Avatar
would there be an issue havig the seat replaced and the airbag "reset" with a stage1 tune (accessport)?
Old May 3, 2009 | 11:54 AM
  #209
blk-majik's Avatar
can anyone comment on the quality of the MR's leather recaros?
Old May 3, 2009 | 02:29 PM
  #210
mathgeek's Avatar
Okay folks. I wouldn't bother having the dealer try to address the staple problem. All the dealer did for me was "re-position" the staple. The fix lasted all of a couple of weeks. I fixed the problem yesterday - permanently. Simply remove the plastic inserts (they pull apart fairly easily). Then use a needle and thread to sew the opposite ends of the seat fabric together (front end to back end). You'll need to pull the ends tightly together while sewing. Basically, you create tension in the fabric so that it doesn't keep coming loose from the foam. Stapling fabric to foam was a bad idea for this particular type of seat. It might have worked otherwise but cut the fabric too short near the inserts.
