Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Evo X Boost Gauge Install ,No splicing, No firewall drilling,Pics+Vid= Clean As Hell
Old Jun 7, 2016 | 05:12 PM
  #256
LB_Reddy's Avatar
What good ports to tap in tranny temp gauge on evo x mr??Cannot get find it.
Old Jun 23, 2016 | 06:18 PM
  #257
TxFAkuma's Avatar
Anyone know what fuse or fuses has a constant 12V power?
Old Jun 24, 2016 | 06:32 AM
  #258
jakgal04's Avatar
I don't know off the top of my head but I can find a source when I get off work tonight.
Old Jun 24, 2016 | 06:42 AM
  #259
redhead714's Avatar
The first post in this thread has this information at the very top... Door Locks.
Old Jun 24, 2016 | 02:33 PM
  #260
TxFAkuma's Avatar
^ I didn't read that and i read every single post / reply in here. lol. I'm going to use this power source to run some exterior led lights and since i have a on and off switch on the controller box provided with the lights i need a constant 12V power supply. How many amps is the door lock fuse?
I forget, When you use a "add a circuit" it is the original fuse that is placed into the first slot and the second slot you place a lower amp fuse... correct? If i remember correctly you want to keep the first fuse amp higher then the once you place into the add a circuit. meaning.. If it is a 10amp fuse (in first slot, closer to the fuse box) then you want to place a lower amp fuse in the second slot so it draws the power from the first.
Old Aug 23, 2017 | 10:48 AM
  #261
terrorz75's Avatar
Hey guys,
Need a little help with the boost gauge, I've had mine on for a few years now and today it completely stopped working. Does anyone know what can be the issue?
Thanks
Old Aug 30, 2017 | 09:28 PM
  #262
forcefedjunkie's Avatar
Aeroforce gauge will read it from the OBD2 port
Old Jan 8, 2018 | 11:40 PM
  #263
cming21's Avatar
Veteran: Air Force
Good write up! Why didn't you just splice in to a constant 12V wire so they are not hanging out of the fuse box under the dash? Not saying it is wrong I just believe it will look better that way. Other than that you did a real good job! Thanks for posting the videos with/out the white wire. It does look good.
Old Jan 17, 2018 | 01:09 PM
  #264
evoguy4242's Avatar
Interesting..
Old May 19, 2018 | 12:36 PM
  #265
Jr147's Avatar
Can someone tell me if you have to t-tab to the middle of the boost vacuum line. or can I just buy extra hose and not have to cut my OEM vacuum line
Old Apr 23, 2019 | 05:47 AM
  #266
Eisen7's Avatar
Bit of a long shot, but has anyone used the stock 3 bar MAP sensor signal into one of the ZT-2's user input channels to drive the ZR-2 boost gauge?
Old Apr 21, 2020 | 01:37 PM
  #267
ProjectGSX's Avatar
My prosport boost gauge doesnt power on until the headlights are turned on. What did I screw up?
Old Apr 22, 2020 | 04:26 AM
  #268
irwintan27's Avatar
Wired it to the headlamps?
EvoX-LI
20
Jul 11, 2019 12:27 PM
mrwickd123
30
Feb 20, 2019 09:29 PM
joseph143
Jan 23, 2018 09:40 PM
Clipse3GT
118
Dec 27, 2016 06:59 PM
mrwickd123
11
Nov 2, 2016 10:19 PM
