Yet another thread about Turboing a 03 lancer.
Old Jun 8, 2010 | 06:54 PM
  #841
03lances's Avatar
Ok I have a question for the tuning gurus. What does it mean when I can do a WOT pull starting at 2000rpms or below and get knock counts 0-3 with an occaisional 5 but yet I can do another run same road same direction right away and if I start my pull around 2500 my knock counts skyrocket like 10-15 counts??
Old Jun 8, 2010 | 07:34 PM
  #842
HornstarBU's Avatar
Knock
How occasional is the 5 knock? I know I can't solve this for you, but I'm getting more curious about tuning. Also, what knock did you see initially before turbo? I remember you said you had the tactrix cable before the turbo and logged a ton, right?
Also, is the knock in a pattern or similar range each pull?
Old Jun 8, 2010 | 07:36 PM
  #843
Chele's Avatar
What does your AFR #'s look like? Maybe because your at higher RPM and your leaning out.
Old Jun 8, 2010 | 08:02 PM
  #844
03lances's Avatar
Bone stock and I mean bone stock I was hitting upwards of 10 counts running regular and seen as high as 14, switching to midgrade brought them down to 5-7 WOT yes the knock counts are pretty consistent
My afrs are pretty good except in the early rpms, this is something I am going to look at I noticed lean spool must still be on I am going to disable that and leave timing alone and see what I get , its so much easier to adjust fuel now with my maf straightened out. Could accel enrichment help this problem you think?
Old Jun 8, 2010 | 08:10 PM
  #845
HornstarBU's Avatar
I dunno, from what Iknow if you see knock and your afr's are fine, it's due to timing.
or bad gas
or phantom (extremely more rare)
So, it's always in the same RPM range when you see it though? and it's consistent like you said, aka reproducible, in that specific range, or just reproducible in the sense that it will show up in "some range" not specifically the same range though.
Old Jun 8, 2010 | 08:16 PM
  #846
03lances's Avatar
Well I am thinking (or hoping) its mostly due to a little high in the afrs I notice when I hit it its around 13 before it drops so hopefully the accel enrich and lean spool disable will correct but suggestions are welcome
Old Jun 8, 2010 | 08:24 PM
  #847
senate6268's Avatar
Lean spool is good to disable for consistent tuning. Accel enrichment will inject more fuel when you hit the throttle and the ECU is catching up with the air being metered in and continue to while the RPMs and speed continue to increase.
Old Jun 8, 2010 | 09:06 PM
  #848
03lances's Avatar
Thanks senate, for some reason the tephra V7 rom I am using says the accel enrichment table is incorrect. Also I looked at the loads I was hitting when first going wot at realized that my fuel table had those load cells still set at 14.7 lol I just adjusted everything back and going to go test it now, disabling the lean spool did help but still needs some work I also started my timing over from scratch I took my stock rom timing values plugged them into the load cells I think they should be then dropped them about 8 degrees to of course compensate for the FI and gave me a dramatic over all boost in hp
Old Jun 10, 2010 | 01:20 PM
  #849
03lances's Avatar
Hey guys I need to know if the 4g94 has a balance shaft or not anybody know?
Old Jun 10, 2010 | 01:45 PM
  #850
RoadSpike's Avatar
If you got a service manual for the engine the timing belt change section would tell you.
Old Jun 10, 2010 | 02:08 PM
  #851
03lances's Avatar
Yup was just looking at that and doesnt look like it.
Old Jun 10, 2010 | 04:30 PM
  #852
senate6268's Avatar
That's a negative.
Old Jun 12, 2010 | 01:23 PM
  #853
HornstarBU's Avatar
stick knock?
After this do you still have knock? during those 2k up pulls
Old Jun 12, 2010 | 01:37 PM
  #854
03lances's Avatar
ya I still have some. I could remove instantly if I wanted to no problem but my power would drop So I just need to go at it slowly. I reinstalled my stock crank pulley which brought my knock counts slightly lower and I am switching over to fine tune the fuel to make sure I take that out of the equation as why I am getting knock. Its not bad at all now mostly 2-3 with a couple 4-5s which I will weed out. I have noticed that I consisently start getting knock even if only 1 count by 2300 rpms at a WOT pull and also see my fuel is still at 13.1 at that point so I am dropping my afrs to 12.5 by 2250 rpms to help with that and just go from there. Had to go help a buddy with his truck it wouldnt start got that fixed for him and now gotta go to work no tuning today oh well tomorrow is another day.
Old Jun 12, 2010 | 01:40 PM
  #855
steven121's Avatar
what would you consider excellent and good afts
