Jake's 06 ES Lancer Build
Old Feb 22, 2015 | 10:04 AM
  #211
jakermeister's Avatar
Fuel pump and resonator are ordered I just need my oil pan welded and my 440 injectors cleaned them I'm ready to start installing stuff.
Old Feb 23, 2015 | 03:00 PM
  #212
marcouxa1's Avatar
Awesome let us know when you start building it!
Old Feb 26, 2015 | 01:12 PM
  #213
Ok guys I got a couple of questions. I think I'm going to hold off on installing my 440 injectors. So do I just convert all my stock injector info into my evo rom? Also I have the evo maf so should I just install that since the maf settings are already in the evo rom? I'm thinking about just starting the project next weekend. It's suppose to snow this weekend.
Old Feb 26, 2015 | 01:48 PM
  #214
marcouxa1's Avatar
Why not just install the 440 cc if you have them....everything is going to work perfect if you use them with my rom
Old Feb 26, 2015 | 03:24 PM
  #215
They've been sitting for about 2 years in a zip lock. I'm not sure how they're going to run. I'd need to get o-rings and the spacers for the injectors. However I do have a sonic cleaner but I'm not able to hook them up and push fluid thru them when they're being cleaned.
Old Feb 26, 2015 | 07:24 PM
  #216
marcouxa1's Avatar
If they were in a zip lock they should be fine....its really easy to install and uninstall too....just buy an oring set for the lancer and they fit the 440cc wrx injectors. I say try them out and if the car runs like crap put the oem injectors back in while u get the 440 cleaned or something no?
Old Feb 26, 2015 | 07:43 PM
  #217
I'll look at the injectors tomorrow. It's snowing here. I think your maps are fine I just need to swap my oem settings for my fuel injectors over? I'll get some pics of the injectors tomorrow.
Old Feb 27, 2015 | 03:41 PM
  #218
marcouxa1's Avatar
Yea but then the latency/voltage wont be right for the oem injectors also...
Old Feb 27, 2015 | 03:56 PM
  #219
I managed to get a definition for my stock rom so I could just transfer that over. I'll try to get pics of the injectors but I think I could just get a repair kit. I might also dip the end of the injectors in my sonic cleaner for a bit just to clean those spraying holes.
Old Feb 27, 2015 | 04:06 PM
  #220
The best pics I could get. There a bit dirty but I need new o-rings and the seater parts on the bottom. Also I got all my parts in today so if everything goes as planned I can start installing the kit next weekend.
Old Feb 28, 2015 | 06:46 AM
  #221
marcouxa1's Avatar
Omg that's it haha? They're fine man just wash them with carb cleaner and you can use your lancer orings and thansfer them over if you want too....but a new set of orings is only like 30$ for the 4 injectors at the autopart if you want them new!
Old Feb 28, 2015 | 08:08 PM
  #222
Yeah I think you're right. I'll order the repair kit. On a update I found a extra engine in the area for $200!!!! So next week I'll probably pick that up if it hasn't sold.
Old Mar 1, 2015 | 06:31 AM
  #223
marcouxa1's Avatar
What are you going to do with another engine though? You want a spare engine in case the other 1 blows?
Old Mar 1, 2015 | 06:35 PM
  #224
Yeah I'm going to build the second engine up and drop it in when it's ready. so next weekend I may be pulling that second engine instead of boosting. The guy doesn't have a cherry picker too so I might have to get one before going to pull the engine. We're getting a bunch of snow here so I hope it's not snowing then. The guy said the car is sitting outside.
Old Mar 1, 2015 | 06:43 PM
  #225
02modlanceroz's Avatar
I hear ya man. I'm so over this snow. Bout ready to get back to working on the lancer and the Evo. Might get to go over the lancer once the weather breaks and I can start driving the evo again. I'm really kicking myself for not picking up a cheap 4g64 when I had the chance
