***ECUFlash Now For Base Lancers!***
Old Sep 15, 2006 | 12:50 PM
  #226
gregivq's Avatar
Originally Posted by crypto
looks out of my league, when i come into some cash i may get it and take it to a tuner shop
BS, start reading our previous posts about tunning and you won't need a tuner shop. Or just make close friends with Hobie, Rhyzin, Boeturbolancer, Alchemist, and others
Old Sep 15, 2006 | 01:04 PM
  #227
rally-on's Avatar
Originally Posted by Z_Lancer_Man
Good questions. If you feel in the least bit uncomfortable or unsure of what you are doing, it is better to NOT try. This software is very powerful and can do much good in the hands of a qualified tuner, but also has the power to destroy your engine if used incorrectly.
In your case, I would just go with a piggyback since I don't think they make flashes for the Ralliart yet. RRM has a good, pre-tuned piggyback for the Ralliart and I'm sure you can pick one up used instead of paying the full price for it from RRM. Good luck!
Z i forgot to put i have a lancer 05 ES 2.0
Old Sep 15, 2006 | 01:10 PM
  #228
Z_Lancer_Man's Avatar
Okay, then. You can still try for a piggyback if you want then. Tuning really isn't that difficult if you put the time in and do a little reading.
And you should change your Profile Info so it doesn't say you drive a Ralliart.
Old Sep 18, 2006 | 07:45 AM
  #229
03RallyLancer's Avatar
zlancer are you able to change the end cells(RPM and Load) to more finely tune the vehicle? Also i was looking at your numbers and getting ready to ask why you were running sooooooo rich then i realized you were turbo... looks good man... if I didnt have the eManage already I would definately be considering this. Great job on being the guinea pig on this one! :thumbsup:
Old Sep 19, 2006 | 04:44 PM
  #230
Kurt's Avatar
I just dropped my car off for tomorrows appointment. To bad I won't have my car back until Thursday due to I go to class right after work and I class lets out at 10:00p.m. I will post results on Thursday evening.
Old Sep 20, 2006 | 10:07 AM
  #231
Redlancer's Avatar
I just place my order for the cable this morning, I have a lot of mod on my car and I can't wait to start tuning it. (And removed the Piggyback at the same time.) I have my AEM wideband on the way too.
Old Sep 20, 2006 | 01:10 PM
  #232
Kurt's Avatar
I just got off the phone with my tuner. He was able to download from my ECU, but was not able to make any changes. Any hints. This is the first Lancer that they have tried to tune.
Old Sep 20, 2006 | 04:53 PM
  #233
So are there no maps that they can select or they just don't know how to edit the values? If the maps aren't selectable or not even there, then they've used the wrong definition file to use with your ROM. If they tried the 1 02 Lancer def file and it's not translating your ROM right, then you need a new definition file made like I needed for my 03.
Old Sep 21, 2006 | 01:25 AM
  #234
N1te's Avatar
SO just for an update from the Original Post, was the other definition file you were working on decoding ever finished?
Old Sep 21, 2006 | 05:03 AM
  #235
Kurt's Avatar
Thanks, I will let them know this. I was kind of upset to hear that it didn't work.
Old Sep 22, 2006 | 06:46 AM
  #236
OZtoEvoWanabe's Avatar
Does anybody got an 02 Manual OZ Lancer that this has worked on?
Old Sep 22, 2006 | 11:18 PM
  #237
Lox1985's Avatar
question....should I even try to tune my piggyback or is it pre-tuned? I got 02 oz manual with exhaust/intake/pulley and piggyback
Old Sep 23, 2006 | 06:13 AM
  #238
crypto's Avatar
Former Vendor
piggybacks are pre tuned, but you can tune them yourself if you want to get more out of it.
Old Sep 23, 2006 | 08:23 AM
  #239
Shingen's Avatar
This thread is about a seperate tuning solution seperate from Piggybacks. Using this flashing method negates the need for a piggyback all together.
Fox
Old Sep 23, 2006 | 03:25 PM
  #240
Wallesasuaz's Avatar
werd, sell the piggy and go ECUFlash... next big thing!
