Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old Apr 30, 2010 | 09:00 AM
  #121
ClixT's Avatar
Originally Posted by link62
ok so i change the memmodel and added the new xml and when to pull the rom off my car and still no go say i need a def files still, and when i read an old rom with the change def file it makes my rpm and loads our of wack and now the auto option arent greyed but they all show 0 or everything
as for the rpms and load, make sure your endians are set to big:
EDIT:for some reason, its working on my laptop but not on my desktop..? wierd
i even reinstalled ecuflash 6 times...
Attached Thumbnails Confirmed:  Evo ROM Can Be Flashed to Lancer ECU-untitled.gif
Old Apr 30, 2010 | 09:07 AM
  #122
RoadSpike's Avatar
Try inheriting from your old xml file if you can then close out ecuflash and see if it created the file. My desktop was being *****y too :P
Old Apr 30, 2010 | 09:09 AM
  #123
ClixT's Avatar
but the thing is, even if theres no def file, ecuflash is still loading it blank...
its like ecuflash have some kind of memory usage like a RAM..
Old Apr 30, 2010 | 09:24 AM
  #124
ClixT's Avatar
i found a fix!
replace your def file on your evo rommetadata!!
ecuflash is reading our ecus as an EVO! lol
so in my case, i have two xmls, one for the 256kb and one for the 512 ones.
the 256kb xml should be in the lancer rommetadata and 512kb should be in the evo one.
Old Apr 30, 2010 | 09:33 AM
  #125
RoadSpike's Avatar
i found a fix!
Hillarious I guess I'll push for an update on ecuflash forums and hopefully get this resolved later thanks for the ground work Clixt
Old Apr 30, 2010 | 09:39 AM
  #126
ClixT's Avatar
i know it is lol
its reading as a 2002 JDM evo 800XXX15.
also, i dont mind ecuflash reading my car as an evo
Old Apr 30, 2010 | 09:57 AM
  #127
RoadSpike's Avatar
i know it is lol
Thats cool you gonna test out the transmission maps?
Old Apr 30, 2010 | 10:14 AM
  #128
4g94T's Avatar
Are you saying the ROM should be placed under the EVO folder instead of the Lancer folder?
Old Apr 30, 2010 | 10:17 AM
  #129
RoadSpike's Avatar
The xml file apparently needs to be there.
There must be some kind of wierd programming bug in ecuflash that makes it think its an evo rom.
Old Apr 30, 2010 | 10:18 AM
  #130
ClixT's Avatar
UPDATE: not all ecus/roms, but in my case yes.
links case needs to be checked first. i need to look at his roms.
@spike: try it out. maybe its just my comp thats f up.
Old Apr 30, 2010 | 10:19 AM
  #131
link62's Avatar
yea im still having no luck when i read my ecu and tell it to inherit from my modded def file i get a blank 512 rom
clixt and Road pm me ur guys emails so i can email you them
Old Apr 30, 2010 | 10:24 AM
  #132
ClixT's Avatar
pm sent
i want you to be done before i leave.. 14 more hours to go.
my flight is may 1st 12:30 am lol
Old Apr 30, 2010 | 10:27 AM
  #133
link62's Avatar
pm sent
email sent and dont worry its my day off so i can try to figure this out all day
Old Apr 30, 2010 | 10:54 AM
  #134
RoadSpike's Avatar
pm sent
Old Apr 30, 2010 | 10:59 AM
  #135
link62's Avatar
pm sent
email sent
