A2-Design Twin Throttle Body Intake Manifold
Old Dec 13, 2006 | 06:03 AM
  #181
gregivq's Avatar
Originally Posted by crypto
couldn't you bored the fuel rail yourself. i heard someone mention its not all that difficult.
If you have access to some machinery and have some skills, I bet it could be a 10 minute job.
Old Dec 13, 2006 | 06:08 AM
  #182
crypto's Avatar
Former Vendor
someone mentioned a dremel.
Old Dec 13, 2006 | 06:40 AM
  #183
gregivq's Avatar
I guess nobody mentioned 'Logic'. How are you going to use a dremel to bore a fuel rail. I'm done. I can't explain more. Search "bored fuel rail" and find what people like Boeturbolancer are talking about.
Seriously.
Damn.
Old Dec 13, 2006 | 06:56 AM
  #184
gregivq's Avatar
Go to your room Crypto.
You need a machine shop to do that for you. I don't know the name of what type of machine you would use but it's not something you can carry around.
Boring is different from drilling in that it uses a single cutting point revolving around a fixed axis to create a round hole. Drills use two or more. You'd be increasing an entire diameter of a hole in your fuel rail.
While porting increases the diameter of an inlet/outlet like in Intake manifold.
Old Dec 13, 2006 | 07:34 AM
  #185
crypto's Avatar
Former Vendor
did someone really delete my post?????
round 2:
i read about the dremel thing in that post about A2's Intake Manifold., The one that got deleted. Someone mentioned that they had used a dremel to bore something out. Thats the only reason i mentioned it.
Old Dec 13, 2006 | 07:38 AM
  #186
Kurt's Avatar
It was deleted because it was answered by gregivq.
Old Dec 13, 2006 | 07:43 AM
  #187
gregivq's Avatar
I understand, that entire thread was filled with stupidity. There is a difference between bore/port and you should really watch out who are you listening to. "newbie" by a user name should definitaly indicate something. And don't think "moderator" is a big deal. "guru" is who you should be talking to.
And if you don't want other members to think you're a dumbass, use wikipedia or google once in a while. Your posts might cause as much confussion as other member's posts.
Back on topic. How's drucea doing?
Old Dec 13, 2006 | 08:09 AM
  #188
Kurt's Avatar
Originally Posted by gregivq
I And don't think "moderator" is a big deal. "guru" is who you should be talking to.
Amen to that.
Like greg said back on topic. It needs to stay that way.
Old Dec 13, 2006 | 11:02 AM
  #189
drucea's Avatar
The stage 3 sucks, end of discussion. the car dies when in nuetral or park.
TheBoz
Oct 18, 2016 03:47 AM
TheBoz
30
Jun 13, 2015 02:47 PM
08MitsubishiGTS
May 15, 2008 11:22 PM
RedOz03
Apr 20, 2007 04:01 PM
ModifiedOZ
Dec 8, 2005 12:37 AM
