Old News!! 4G64 Swapped Into A 2002 Lancer
Old Oct 19, 2007 | 10:26 PM
  #286
True_Story's Avatar
Originally Posted by Disruptorzero
Don't quote me but I think you need everything from the 4G64, wiring included.
i understand that part but i would like to know if the g64 will plug into my car harness!!
Old Oct 20, 2007 | 06:52 AM
  #287
Jehuty's Avatar
lol, bro it should be on the first page if I'm not mistaken, read that over again I know that it mentions the harness
Old Oct 20, 2007 | 08:43 AM
  #288
True_Story's Avatar
it does mention the harness but not if it plugs directly into the car harness!!
Old Oct 20, 2007 | 09:21 AM
  #289
Juan Martinez's Avatar
Its probably all the same. I would think of it as one of those honda swaps where you have to take the whole harness from under the hood and run it into the interior. Plug it up to the the ecu and plug the interior harness into the ecu.
Old Oct 20, 2007 | 09:22 AM
  #290
Blacksheepdj's Avatar
I'd guess it plugs in. If it was a Subaru swap (where you're merging harnesses), I'm sure that would have been discussed in the writeup.
Old Oct 20, 2007 | 09:25 AM
  #291
True_Story's Avatar
kool..good looking out guys !
Old Oct 20, 2007 | 06:02 PM
  #292
Jehuty's Avatar
np, with the questions that you are asking, I'm guess that you are either doing this swap, or maybe close to starting, am I correct?
Old Oct 20, 2007 | 11:08 PM
  #293
True_Story's Avatar
^^getten ready to start gathering the parts yes!!!
Old Oct 21, 2007 | 08:48 AM
  #294
Jehuty's Avatar
high five'a yes! Very nice! How much? for all the parts ur gathering?
Old Oct 21, 2007 | 12:19 PM
  #295
True_Story's Avatar
4g64 block with crank $$60
thats for now!!
Old Oct 21, 2007 | 12:23 PM
  #296
Jehuty's Avatar
SIXTY BUCKS?!?!?! for the block? Is the whole engine, and the block two different things? I never understood that.
Old Oct 22, 2007 | 12:28 PM
  #297
True_Story's Avatar
block is the bottom part of the motor....pistons,crankshaft,and oil is some of the things in the block .....head is the top,most visable part of the motor....that contains the cams...valve springs spark plugs and so on..... !!!!
BLOCK!!!
HEAD!!!
HEAD AND BLOCK TOGETHER!!
Old Oct 22, 2007 | 03:15 PM
  #298
Thats a dsm block 4g63t thats backwards from ours.
Old Oct 22, 2007 | 06:49 PM
  #299
SnapDragun's Avatar
"Gets smacked wit da noOob stick for not knowing that"
Old Oct 23, 2007 | 04:57 AM
  #300
Jehuty's Avatar
I deserve it, lol. I honestly never knew the difference. So mating the evo head with the g64 BLOCK, is that the "great thing" about this swap?
